Spoilboard Maintenance Tip - Router Forums
 1Likes
  • 1 Post By gmedwards
post #1 of 2 (permalink) Old 03-30-2019, 03:32 PM Thread Starter
First Name: Gary
Default Spoilboard Maintenance Tip
Here's a tip that just came to mind. For anyone inclined to fix minor cuts in the spoilboard, 3M Glazing and Stop Putty (the red stuff used by auto painters) works great. It's lacquer based, so it dries quickly. It's easy to sand smooth, and doesn't cause MDF to swell. Durham Rock Hard works well for deeper cuts, but because it uses water to mix it up, it will cause some minor MDF swelling. It's localized, so sanding the putty does an adequate job of of leveling everything out. This is a good way of extending the life of your spoilboard. You can find the glazing and spot putty and Durham Rock Hard at the big box and most hardware stores. The glazing & spot putty is also usually available at auto parts stores.
Gary
Scottart likes this.
gmedwards is offline
post #2 of 2 (permalink) Old 03-31-2019, 02:58 PM
kp91's Avatar
First Name: Doug
Bondo and MDF work well together!
1 John 1:9
Fredericksburg, VA
kp91 is offline
I received this clever but simple tip today harrysin Lobby 5 11-26-2016 05:06 AM
woodsmith tip (router maintenance ) Semipro General Routing 25 02-01-2016 12:44 PM
dado blade for spline joining sjonesphoto Tools and Woodworking 34 03-11-2014 11:11 AM
Scroll Saw Maintenance berry Wood Scrolling 2 09-11-2013 05:26 PM
Tip Rotator Mark Site Help and Suggestions 4 03-10-2008 10:22 AM
