Finding an alturnitive to my alturnitive work holding... well kinda - Router Forums
 16Likes
post #1 of 12 (permalink) Old 04-05-2019, 07:09 PM Thread Starter
Gary Wiant's Avatar
First Name: Gary
Default Finding an alturnitive to my alturnitive work holding... well kinda
Full disclosure I posted this over on CNCZone but I wasnt sure how many people frequent both forums.
So I have a CNC Router Parts Pro 4896 with a custom vacuum table with t-slots running around the outside plus through the center of both axis.
I do a lot of routing on rough cut slabs that are typically around 20" wide so I can normally reach the slab with the t-slot clamps but this time my chainsaw guy brought me some smaller pieces (between 7.5" &12") but my problem was how am I going to hi- old them down? I refuse to screw into my spoil board because of the vacuum table.
So what I ended up coming up with was screwing 1/2" MDF to the bottom of the slabs.
It took a little bit to get it squared up being they are live edge but it works great with the extra 1/2" I was able to set my cut depth to an extra 1/8" so I was sure I was going to route the whole way through the wood.
I route these then my chainsaw buddy roughs them up with the chainsaw & burns them to seal them. These are the first 4 I made more to come. The only thing I'll change is I will probably do pocket cuts especially for the 2" thick pieces because when the pieces get cut away they make a very loud noise bouncing around in the hole. I also cut these with a 3/8" bit the next time I'll use my1/2" bit so I can take deeper passes.
Thanks for looking
Gary
MEBCWD, MoHawk and OCEdesigns like this.
I'm here to learn about CNC routing & anything else I can pick up.
God bless
Gary Wiant is offline
post #2 of 12 (permalink) Old 04-05-2019, 07:44 PM
RainMan 2.0's Avatar
What a great idea Gary ,those are really nice.
Gary , do need the 8’ foot Y axis very much , as I was debating to go with a 4x4 if I ever get one
Ok ,I never insulate
RainMan 2.0 is offline
post #3 of 12 (permalink) Old 04-05-2019, 08:03 PM Thread Starter
Gary Wiant's Avatar
First Name: Gary
I own a sign shop and we use the 8' y axis a lot. The gone fishing sign was 87". I've actually already needed a 10' table already ( I'm new & not sure how to cut a job bigger than my table. )
Gary
RainMan 2.0 likes this.
God bless
post #4 of 12 (permalink) Old 04-05-2019, 08:20 PM
Pro4824's Avatar
First Name: Joe
Gary
If you had a Pro4824, you would have learned tiling by now. 😉
Great signs Gary!!
MEBCWD and MoHawk like this.
Pro4824 is offline
post #5 of 12 (permalink) Old 04-05-2019, 08:38 PM
Gary
segment the sign...
assemble the segments into a panel w/ splines...
@Scottart has done this very same thing..
MEBCWD, MoHawk and Scottart like this.
Stick486 is offline
post #6 of 12 (permalink) Old 04-05-2019, 09:23 PM
Scottart's Avatar
First Name: Scott
great pieces Gary
Yep, watch the Vectric tutorials on Tiling and there are no longer any size constraints...
MEBCWD, OCEdesigns and OCEdesigns like this.
Man with out Vision shall perish..women too!
Find more of our stuff on Etsy
https://www.etsy.com/shop/CreekWillo...platform-mcnav
Scottart is offline
post #7 of 12 (permalink) Old 04-05-2019, 09:54 PM
difalkner's Avatar
First Name: David
Thanks for looking
Gary
Nice work, Gary. I would be far more concerned about a piece you've cut getting wedged in the opening and bending or breaking a bit than I would about the noise. Can you leave tabs to hold the piece in place and cut it out later after you've removed the entire piece from the CNC? Seems like that would be far safer.
David
TimPa and MEBCWD like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #8 of 12 (permalink) Old 04-06-2019, 04:47 AM Thread Starter
Gary Wiant's Avatar
First Name: Gary
I'll watch the vectric tiling videos, the you tube videos I've watched have wanted hole drilled into the spoil board & I dont want to do that to my vacuum table spoil board.
David - good idea, I use tabs all the time when I am keeping the loose pieces I'm routing out. The tabs never even crossed my mind.
The pieces that were big enough to reach I would hold them down by hand. I know not the smartest thing to do but I'm a big guy so my body weight held them pretty good most didnt even move at all.
Thanks all
God bless
post #9 of 12 (permalink) Old 04-06-2019, 06:56 AM
MoHawk's Avatar
First Name: Bob
Gary , do need the 8í foot Y axis very much , as I was debating to go with a 4x4 if I ever get one
That's my only regret in the 2+ years owing my Pro4824, wish I bought 4848. If I can ever find time to move mine from the basement to my large shop I will extend it to 48, maybe even 96.
Retirement is sure time consuming!
MEBCWD and RainMan 2.0 like this.
Bob aka MoHawk & Gigawatt
CNCRP Pro4824, Aspire 10, Mach4, VistaCNC M1 Pendant
MoHawk is offline
post #10 of 12 (permalink) Old 04-06-2019, 09:42 AM
Pro4824's Avatar
First Name: Joe
Retirement is sure time consuming!<a href="http://www.routerforums.com/images/RouterForums_2015/smilies/tango_face_smile_big.png" border="0" alt="" title="Laugh" >:-)</a>
Same here although 99% of my projects are smaller than 24"x48"
It's just knowing that you CAN expand that's tempting. &#x1f642;
Until then, I was thinking of adding an "outfeed table" to make tiling projects easier.
Pro4824 is offline
Work Holding Jigs MT Stringer Lobby 13 11-16-2016 07:26 PM
