Painting on CNC routed signs bleeding into grain - Router Forums
 20Likes
post #1 of 17 (permalink) Old 04-07-2019, 07:18 PM Thread Starter
Gary Wiant's Avatar
First Name: Gary
Default Painting on CNC routed signs bleeding into grain
I've been doing like everyone does. using spray paint to paint the routed sections then sanding off the paint to only leave the routed areas painted. But I've been noticing the paint bleeding into the grain. I've even painted the wood with sanding primer prior to painting but that didnt seem to make much of a difference.
Does anyone have any tips on ways to keep the paint from bleeding?
Will it be better to paint with a brush?
Does using an airbrush make any difference? I've heard that the atomized paint makes sanding easier.
Thank you
Gary
I'm here to learn about CNC routing & anything else I can pick up.
God bless
Gary Wiant is offline
post #2 of 17 (permalink) Old 04-07-2019, 07:51 PM
difalkner's Avatar
First Name: David
What kind of wood and paint, Gary? I have sealed bare wood areas with Nitrocellulose sanding sealer or Shellac and then painted with no real issues. I've used both brush and spray (rattle can). I've used my air brush for small areas but usually seal them first.
David
MEBCWD and UglySign like this.
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is offline
post #3 of 17 (permalink) Old 04-07-2019, 08:33 PM Thread Starter
Gary Wiant's Avatar
First Name: Gary
David wood is all over the place, anything from rough cut, air dried pine, hemlock, white oak & maple to kiln dried pine, oak, cherry & maple.
How many coats of sanding primer do you use when you applying it?
Gary
God bless
post #4 of 17 (permalink) Old 04-07-2019, 10:13 PM
difalkner's Avatar
First Name: David
Not sanding primer, Nitrocellulose sanding sealer - clear, like I use on a clear lacquer finish. One will do it, or has. I suppose you could do two to make sure since it doesn't take long to dry.
David
OCEdesigns likes this.
David
Romans 3:23
post #5 of 17 (permalink) Old 04-07-2019, 10:30 PM
JOAT's Avatar
First Name: Theo
No, not every one. The few times I paint anything I use a brush, acrylic latex, and have never had any bleeding issues.
Gather the villagers, pitchforks, torches; we march at dusk!
JOAT is online now
post #6 of 17 (permalink) Old 04-07-2019, 10:49 PM
Gary,
On big projects like this one (37" across) I just brushed over the text with Zinser shellac and used acrylic paint, sanded, and stained.
On the smaller signs I use mask and acrylic paint - brushed on. Acrylic paint doesn't bleed much and sands right off. I've found that brushing instead of spraying, although more time consuming, leaves less to clean up, and looks better, especially in wood with rough grain. I've tried the Marsh Ink - but I think it looks like sprayed on ink.
Just my opinion. But I'm not paying anyone either, so time doesn't mean as much.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #7 of 17 (permalink) Old 04-07-2019, 11:03 PM Thread Starter
Gary Wiant's Avatar
First Name: Gary
Joat - your right not everyone but, but you are still basically doing the same thing. Paint it on & sand it off.
David & John I'll post a photo of what I've been using it may be sanding sealer & not sanding primer
God bless
post #8 of 17 (permalink) Old 04-08-2019, 07:37 AM
difalkner's Avatar
First Name: David
This is about the only photo I have that shows something where I used Nitrocellulose sanding sealer and then brushed the letters and sprayed the apple. I don't see any bleeding in the photo and don't recall any when I did this.
David
chessnut2, MEBCWD and beltramidave like this.
David
Romans 3:23
post #9 of 17 (permalink) Old 04-08-2019, 10:02 AM
Honored Member
harrysin's Avatar
First Name: Harry
As has been said, shellac is a perfect sealer, I wouldn't be without it.
Harry
harrysin is offline
post #10 of 17 (permalink) Old 04-08-2019, 11:03 AM
JOAT's Avatar
First Name: Theo
Nope, I do my sanding before painting, not after, just paint very carefully.
JOAT is online now
Routing & Painting Name Signs JoeM Sign Making 17 10-07-2014 11:30 AM
wood carved or routed signs graphicsmom Sign Making 10 08-31-2009 10:08 AM
finishes for routed wood signs bob e The Finishing Touch 20 02-01-2009 05:19 PM
Using India ink for coloring routed signs bob e New Member Introductions 2 12-06-2008 01:54 AM
Freehand routed signs, for AxlMyk harrysin Sign Making 3 12-27-2007 07:07 AM
