Best wood glue? - Router Forums
 66Likes
post #1 of 37 (permalink) Old 04-10-2019, 08:22 AM Thread Starter
OCEdesigns's Avatar
First Name: Chad
Default Best wood glue?
I know I could have put this in a different area but since I use a CNC I figured I would ask here.
I'm starting to make a few things that will need to be glued together. Some before milling and some after milling. Is there a "Best" wood glue to use? I'm not making cutting boards (yet!) but something similar. How long should I wait after gluing before I mill? Any thing else I need to be careful of when milling after gluing the boards?
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #2 of 37 (permalink) Old 04-10-2019, 08:50 AM
difalkner's Avatar
First Name: David
I use TB original for most things, Chad, and usually wait a couple of hours. It depends on what and how the pieces are glued and I probably wait longer than necessary. For cutting boards, and we've built about 75 so far, I use TB III and wait 3-4 hours, sometimes overnight.
David
MEBCWD and OCEdesigns like this.
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #3 of 37 (permalink) Old 04-10-2019, 08:57 AM Thread Starter
OCEdesigns's Avatar
First Name: Chad
Thanks David! The stuff I'll be gluing are boards 2-3" wide 3/4" thick and will glue 3 or 4 together at a time. I planned on waiting 24 hours but didn't know if that was enough or not.
I'll pick up some TB III this weekend.
post #4 of 37 (permalink) Old 04-10-2019, 10:22 AM
difalkner's Avatar
First Name: David
I typically glue cutting board pieces all at once. TB III has enough open time to do this if you're organized in your glue up.
David
David
Romans 3:23
post #5 of 37 (permalink) Old 04-10-2019, 10:27 AM Thread Starter
OCEdesigns's Avatar
First Name: Chad
That looks awesome David!
difalkner likes this.
post #6 of 37 (permalink) Old 04-10-2019, 11:41 AM
JOAT's Avatar
First Name: Theo
Depends on which glue makes you happiest. I don't care for Titebond original, never tried Titebond III, just use Titebond II. I'm sure other wood glues would work as well, but I'm happy as is. I normally glue whatever, go on to something else, and let the glueup sit until the next day.
OCEdesigns likes this.
Gather the villagers, pitchforks, torches; we march at dusk!
JOAT is offline
post #7 of 37 (permalink) Old 04-10-2019, 12:19 PM
The answer is it depends on the glue you are using. No one glue is the best for every job. I keep at least 6 different glues around. Cyanoacrylate and hot melt are good if you need a really quick bond so you can keep working. Polyurethane is good for waterproof but joints have to be tight, the foam has no strength. Fiberglass resin is also waterproof and makes an excellent wood glue and it dries fairly quickly especially if you add a little extra catalyst and it will fill gaps. Titebond 3 is almost waterproof but it leaves a brown glue line which really shows on light colored woods. Most glues have some level of water resistance and I prefer using something like Weldbond which dries clear. I always have a bottle of Titebond Melamine glue around for gluing particle board and mdf. And I also always have a bottle of Lee Valley fish glue around too. It's stays water soluble and there are a lot of jobs I use it on.
JFPNCM, MYB, tulowd and 1 others like this.
post #8 of 37 (permalink) Old 04-10-2019, 12:30 PM
like Chuck said, there is no one best glue. in our shop, Titebond II is our go to for most all glue-ups. clamp time is 1/2 hr min, and full strength in 24 hours, we keep clamped overnight. tbIII for exterior, and TB or hyde glue for more open time. all have their pro's and con's.
TimPa is online now
post #9 of 37 (permalink) Old 04-10-2019, 01:08 PM
I use Titebond II blue light glue for everything.
Herb Stoops is online now
post #10 of 37 (permalink) Old 04-10-2019, 02:01 PM
JFPNCM's Avatar
First Name: Jon
@didalkner
David: great looking board!
I assume each of the horizontal rows was glued up prior to the entire board being put together.
Cheers
Jon
Jon
JFPNCM is online now
can you see the glue? sunnybob General Routing 16 01-10-2016 01:31 PM
New to wood working and to this forum. jaithran New Member Introductions 9 11-25-2014 01:50 AM
Maloof Inspired rocking chair build TwoSkies57 TwoSkies57 Gallery 235 07-13-2014 06:29 PM
glue plastic to wood Kelly Rittgers Jigs and Fixtures 11 02-14-2011 03:22 AM
A Wood Experience-Contest Woodworkers Source Contests Archive 2 05-14-2009 06:58 PM
