Weird pattern on profile cuts - Router Forums
 12Likes
post #1 of 15 (permalink) Old 04-10-2019, 09:00 AM Thread Starter
Gary Wiant's Avatar
First Name: Gary
Default Weird pattern on profile cuts
I just noticed this occurring on a job I just finished. I routed a total of 6 signs all had this type of finish on the edges.
Router is CNC Router Parts Pro4896 with Nema 34's & their spindle.
Material is kiln dried Maple.
Bit is a new Onsrud 40-112 1/4" downcut
Any help is greatly appreciated
Gary
I'm here to learn about CNC routing & anything else I can pick up.
God bless
Gary Wiant is offline
post #2 of 15 (permalink) Old 04-10-2019, 09:09 AM
OCEdesigns's Avatar
First Name: Chad
What was your spindle speed and feed rate? Was it climb cutting or conventional?
I had something similar on a profile cut in yellow pine 1/4" EM but up cut. I was getting some chatter and changed to a conventional cut and it was better.
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #3 of 15 (permalink) Old 04-10-2019, 09:19 AM Thread Starter
Gary Wiant's Avatar
First Name: Gary
I think it was 150 feed rate cant remember the spindle speed. I'm pretty sure it was climb cut. I can check later when I get back to the shop
Gary
OCEdesigns likes this.
God bless
post #4 of 15 (permalink) Old 04-10-2019, 10:28 AM
difalkner's Avatar
First Name: David
About a year ago I began leaving 0.005" on profile cuts (climb) and follow with the clean up cut in conventional, full depth. This has allowed me to eliminate sanding edges, in most cases.
Give that a try, Gary.
David
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #5 of 15 (permalink) Old 04-10-2019, 11:42 AM Thread Starter
Gary Wiant's Avatar
First Name: Gary
David I really like the sound of that. So you climb cut initially and leave .005 and finish pass it with a conventional cut?
God bless
post #6 of 15 (permalink) Old 04-10-2019, 04:25 PM
difalkner's Avatar
First Name: David
Yes sir, just like that. The climb cut takes me all the way down to the spoilboard in steps and then the finish cut is conventional at full depth to clean up the final 0.005". Works like a champ! I keep the same feed/speed about 90% of the time. Occasionally I'll slow the feed slightly, depending on the piece and the wood type. For me that's mostly Walnut but Maple and Cherry sometimes respond differently and I'll keep the feed at the same rate as the climb cut - in the 150 ipm to 250 ipm range, again depending on what I'm cutting.
On my Longworth chucks, which are cut from 1/2" BB, I have the final pass remove the tabs because the center piece is screwed to the spoilboard. This saves me from having to trim and sand the tabs flush. But most pieces aren't screwed to the spoilboard and I can't do that.
David
David
Romans 3:23
post #7 of 15 (permalink) Old 04-10-2019, 05:59 PM
ger21's Avatar
First Name: Gerry
Personally, I almost never climb cut wood, as it will almost always result in a poorer finish.
The only time I climb cut is when cutting rabbets along the grain, or other similar cuts that will tear out with conventional cuts.
Ger
www.cncwoodworker.com
ger21 is offline
post #8 of 15 (permalink) Old 04-12-2019, 10:12 PM Thread Starter
Gary Wiant's Avatar
First Name: Gary
I tried a job with conventional cut, & the final pass allowance & let it take .02" & it worked great.
I reversed direction on the final pass. Is that correct?
thanks guys
God bless
post #9 of 15 (permalink) Old 04-12-2019, 10:50 PM
difalkner's Avatar
First Name: David
I do climb cut on the profile and conventional on the final, Gerry does conventional most of the time. I think as long as the final is conventional you'll be ok, even if the rough cut was conventional. To keep down the opportunity for chatter I would drop the final pass to below 0.010". I do my final pass at 0.005" so it's just taking a light shaving all the way around.
David
David
Romans 3:23
post #10 of 15 (permalink) Old 04-13-2019, 08:05 AM Thread Starter
Gary Wiant's Avatar
First Name: Gary
I use Aspire, How do you change the type of cut between the regular cut & final cut? Do you run them as seperate toolpaths?
Also when setting up the profile toolpath there is a check box for allowance distance. If n the next box down I'm taking a final pass of .01" do I want to leave .01 in the initial profile toolpass setup?
Thank you
Gary
God bless
Using a pattern bit? tvman44 General Routing 16 03-01-2015 10:25 AM
Trouble Pattern Routing - Help Appreciated marc82much Table-mounted Routing 21 05-06-2014 12:07 AM
Cross Cuts Differ From Rip Cuts... Jerry Bowen Tools and Woodworking 9 07-15-2013 12:27 PM
Jerry's latest observation on accurate cross cuts Jerry Bowen Tools and Woodworking 32 10-15-2012 11:34 PM
