Evenly spaced pockets - Router Forums
 3Likes
  • 3 Post By Gaffboat
post #1 of 3 (permalink) Old 04-10-2019, 09:05 AM Thread Starter
OCEdesigns's Avatar
First Name: Chad
Default Evenly spaced pockets
I was busy these last days and now have more questions! LOL
I use Vcarve Pro 9.5. I'm sure it's in there but I could not find it. I have a design where I am making 6 circular pockets and need them 3/4" apart from each other in a straight line. Is there a fast way to have the program auto space them for me? At the bottom of the drawing tab it looks like what I need but it would not let me enter any values. Unless I'm missing something else.
I'll be making similar designs soon and hope I can do it because manually doing it to get it just right is very time consuming!
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #2 of 3 (permalink) Old 04-10-2019, 11:51 AM
Gaffboat's Avatar
First Name: Oliver
Use the Array tool (bottom row, second icon from the left) to space the pockets. Draw one vector circle, select it, and then go to the Array tool. In the array dialog box, put .75" for the gap between circles, and 6 for the number of columns. (I only show 5 in my sample because the material setting wasn't long enough.) Click "Copy" and you're done. Easy peasy.
TimPa, MEBCWD and OCEdesigns like this.
Gaffboat is online now
post #3 of 3 (permalink) Old 04-10-2019, 11:58 AM Thread Starter
OCEdesigns's Avatar
First Name: Chad
Thank you!!! I tried that but I had already made my circles! This makes more sense now and thanks a lot for the screen shots. I knew there had to be a way to make it faster.
Katie/Sommerfield Jig ? on Variably Spaced DT jackson74 Jigs and Fixtures 3 04-23-2016 02:00 PM
Strange Pockets Crosetti CNC Routing 7 06-22-2015 07:40 PM
Zebra wood gum pockets and routing Drew Eckhardt Wood Species 0 10-20-2011 10:30 PM
Narrow spaced dados gusinpa Jigs and Fixtures 17 09-11-2010 10:59 PM
routing accurately spaced grooves in boards for a house entryway system? paulcomi General Routing 8 06-16-2010 08:49 AM
