5 axis CNC router recommendation - Router Forums
 10Likes
  • 1 Post By Klavimaniac
  • 3 Post By BalloonEngineer
  • 4 Post By ger21
  • 2 Post By 4DThinker
post #1 of 9 (permalink) Old 04-25-2019, 11:16 PM Thread Starter
Default 5 axis CNC router recommendation
Can anyone recommend a 5-axis CNC router that can carve complex 3D wood sculptures? It needs to be making ca. 25''x25'' objects and on the Z-axis about 5'' as a minimum. It does not need to be fast nor does it need to carve many objects. Precision should be around 0.01mm. The attached pic is the final sculpture (a piano leg) that would need to be assembled from horizontally sliced sections of the total leg (ca. 5'' in height).
Since it's for less than 10 legs the router should not be above 10K.
Alternatively, if anyone knows of a reasonable CNC firm that can make the product for me, that would be fine, too.
Thank you!
Scottart likes this.
Klavimaniac is offline
post #2 of 9 (permalink) Old 04-26-2019, 01:36 AM
Scottart's Avatar
First Name: Scott
Thank you!
pictures please
Man with out Vision shall perish..women too!
Find more of our stuff on Etsy
https://www.etsy.com/shop/CreekWillo...platform-mcnav
Scottart is offline
post #3 of 9 (permalink) Old 04-26-2019, 08:57 AM
BalloonEngineer's Avatar
First Name: Richard
5 axis for under 10k will be very tough. Given the low volume and your plan to mill in slices, it is likely it can be done one a 3-axis with doing the individual slices on two faces, or as an indexed rotary. Would need to see the geometry to make a recommendation.
.01mm is quite tight for wood, it will easily move that much with a slight change in humidity. You generally will not get a part off a Router that needs no sanding, so those kinds of tolerances are just not realistic.
difalkner, MEBCWD and OCEdesigns like this.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #4 of 9 (permalink) Old 04-26-2019, 09:16 AM
difalkner's Avatar
First Name: David
Welcome to the forum! Add your first name to your profile so it shows in the side panel and clears the N/a and so we'll know what to call you. Add your location, as well, as that often helps us to help you.
Like Richard said, that's going to be hard to do for under $10k.
You can post photos if they're on your computer. Just drag and drop to the section below this dialogue box or click Go Advanced and choose the paper clip to browse to your photos.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #5 of 9 (permalink) Old 04-26-2019, 08:39 PM
ger21's Avatar
First Name: Gerry
About the cheapest 5 axis you'll find is this shopbot, at $45,000.
https://support.shopbottools.com/products/5axis
I doubt it would be anywhere near .01mm accuracy. You're looking for a $300,000 machine.
Ger
www.cncwoodworker.com
ger21 is offline
post #6 of 9 (permalink) Old 04-27-2019, 02:33 AM
First Name: 4D
Where I work we've repeatedly debated the need for a 5-axis CNC. We invariably conclude that the "thing" we wanted to make that required the 5-axis could actually be done on a $5k machine with a compound angle clamping jig mounted in it: 4D Furniture Thoughts: Advanced Compound Angle CNC Clamping Fixture.
Sometimes by just re-imagining how to split the "thing" into halves or slices so all parts could be machined then assembled to make the whole.
4D
difalkner and MEBCWD like this.
4DThinker is offline
post #7 of 9 (permalink) Old 04-28-2019, 09:49 PM
MEBCWD's Avatar
If you are talking about making piano legs I don't see the reason for the requirment for the 0.01mm tolerance or need for a 5th axis. It might be best done on a rotary axis after the blank is glued up, as you say it doesn't have to be fast. Done on a rotary axis like this all kinds of design possibilities are possible, your imagination is the only thing to hold you back.
MEBCWD is offline
post #8 of 9 (permalink) Old 05-01-2019, 08:18 PM
First Name: Scott
Sounds more like you need a CNC lathe which would have 3 Axis with a router used as the cutting tool rather than the gouges.
You should be looking for a CNC lathe which has 3 Axis. You don't need a 5 Axis machine to make piano legs.
If you want to go old school; Wood Smith Magazine has plans for a router lathe you can build. Granted, the machine is not CNC, but then, you are turning legs and other such parts.
On the other hand, if your just looking for an excuse to purchase a 5 Axis CNC machine, then just purchase one, but it will break you budget. The best course of action to a 5 axis machine is to first make money using a 3 axis machine.
SATovey is offline
post #9 of 9 (permalink) Old 05-01-2019, 11:05 PM
Traupmann's Avatar
You need to discuss this with someone with experience in cutting 3-axis and 5-axis parts. I believe you will find that you need a 3-axis machine with the right tooling.
A 5-axis machine is needed to cut swarfs such as moldline in aircraft. With 40 years of programming aerospace parts in numerous materials and many, many machine types, I can tell you that a 3-axis is more likely to produce a better part with fewer hassles.
"There is a cult of ignorance in the United States, and there has always been. The strain of anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that my ignorance is just as good as your knowledge." Isaac Asimov
Traupmann is offline
Need advice CNC End mills Vs. router bits SubmarineGuy CNC Routing 8 11-17-2014 07:59 AM
Whats the best CNC 4 axis Router ? Sonnybanjo CNC Routing 2 12-03-2013 07:03 AM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
