Advantech flooring for spoilboard. - Page 3 - Router Forums
 31Likes
post #21 of 24 (permalink) Old 05-09-2019, 09:54 PM
difalkner's Avatar
First Name: David
Looks good, Mike. I've thought about adding photos to the folders but just haven't started that yet. After seeing yours I may start.
The reason mine start with 001 is because if you get to 10 they won't be in order if sorted by name. 01 would work, as well, unless you're going to have more than 99 operations (doubtful).
David
MEBCWD likes this.
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is offline
post #22 of 24 (permalink) Old 05-10-2019, 02:41 AM
MEBCWD's Avatar
David
I hope I don't have a project that has 99 tool changes! I might start using the longer form if I ever get the chance to get back on my own files.
I started including pictures of the cut gcode previews along with customer files so they could look at how a file should look and be able to add extra clamps if needed. On some of their pictures, I edit and show safe places for clamps. I ask some of them if they would like a file to cut first to show the safe areas but have always been told no, they did not need one or they did not want to do another tool change. I even said I could just use the starting tool and make a shallow plunge at a few safe spots but they don't want that either.
MEBCWD is offline
post #23 of 24 (permalink) Old 05-10-2019, 12:07 PM Thread Starter
Pro4824's Avatar
First Name: Joe
I'm using that method to locate (Safe Spaces) for pin nails on this project. I can't believe I used that term but it works great!!
MEBCWD likes this.
Pro4824 is offline
post #24 of 24 (permalink) Old 05-10-2019, 04:33 PM
difalkner's Avatar
First Name: David
I do that, as well, Joe. Many times in certain projects I'll clamp from the outside and use the CNC to drill safe places to place screws in the interior. Then I'll remove the outside clamps and cut the outer profile. Those usually end up being file 001 -
David
MEBCWD and timon2jkl like this.
David
Romans 3:23
Help identify wood flooring jameston Wood Species 18 04-10-2015 08:16 PM
matching tongue and groove for old flooring DWybo New Member Introductions 11 01-26-2015 08:40 PM
Laminate Flooring berry General Routing 9 04-24-2009 11:01 PM
5 Tips When Choosing Hardwood Flooring John_smith Project Plans and How To 0 10-17-2008 06:19 AM
