Advantech flooring for spoilboard. - Router Forums
 31Likes
post #1 of 24 (permalink) Old 05-01-2019, 10:40 PM Thread Starter
Pro4824's Avatar
First Name: Joe
Default Advantech flooring for spoilboard.
It's time for a new spoilboard so instead of MDF, I'm using a piece of Advantech flooring that I had leftover from my last remodel project. It's way stiffer and holds screws better than plywood or chipboard and definitely MDF so time will tell but so far it surfaced great and I've got high expectations but I've never seen anyone else using it so we'll see...
Pro4824 is offline
post #2 of 24 (permalink) Old 05-02-2019, 01:08 AM
BalloonEngineer's Avatar
First Name: Richard
Also waterproof, so humidity swelling should not be an issue. I think it will prove a good decision.
MEBCWD likes this.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #3 of 24 (permalink) Old 05-02-2019, 01:25 AM
MEBCWD's Avatar
Looks good to me. Like you say time will tell.
MEBCWD is offline
post #4 of 24 (permalink) Old 05-02-2019, 08:19 AM
difalkner's Avatar
First Name: David
And until you surfaced the writing off, Joe, it had a limited lifetime warranty...
David
MEBCWD and OCEdesigns like this.
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #5 of 24 (permalink) Old 05-02-2019, 09:09 AM Thread Starter
Pro4824's Avatar
First Name: Joe
Well, that was the main reason for this decision. My top layer of MDF would change shape sometimes multiple times a day. It was screwed instead of glued to the bottom layer but I wanted it to be easily replaceable. I think this will be better.
Funny David! Maybe I can use a sharpie and get my warranty back???
It's raining and the shop doors are open and the spoilboard is still as straight as a Harbor Freight straight edge!! 😉 My Z accuracy is gonna be a welcome improvement.
Pro4824 is offline
post #6 of 24 (permalink) Old 05-02-2019, 09:55 AM
chessnut2's Avatar
It sounds like a great idea, Joe. I never thought of Advantech, even though I've used it and can attest to it's stability and resistance to moisture. And I'm glad to hear that it surfaced OK. Thanks!
chessnut2 is offline
post #7 of 24 (permalink) Old 05-02-2019, 10:21 AM
difalkner's Avatar
First Name: David
I don't do any remodeling or use material like that, so without doing any searches yet I have to ask is Advantech flooring is just a brand of OSB flooring? I'm heading to Lowe's later and I can look at OSB flooring there unless Advantech flooring is different (they may have Advantech for all I know...).
David
David
Romans 3:23
post #8 of 24 (permalink) Old 05-02-2019, 12:48 PM Thread Starter
Pro4824's Avatar
First Name: Joe
It looks like osb but it's alot better.
Lowes has it.
https://www.huberwood.com
difalkner likes this.
Pro4824 is offline
post #9 of 24 (permalink) Old 05-02-2019, 12:57 PM
MEBCWD's Avatar
David
Here is a link to find dealers near you David https://www.huberwood.com/locations
Also Lowes here carries it in all the store, I tried the link I sent and several local lumber yards have it.
MEBCWD is offline
post #10 of 24 (permalink) Old 05-02-2019, 01:16 PM
brand name of T&G subfloor decking
Help identify wood flooring jameston Wood Species 18 04-10-2015 09:16 PM
matching tongue and groove for old flooring DWybo New Member Introductions 11 01-26-2015 09:40 PM
Laminate Flooring berry General Routing 9 04-25-2009 12:01 AM
5 Tips When Choosing Hardwood Flooring John_smith Project Plans and How To 0 10-17-2008 07:19 AM
