First pass is too deep - Router Forums
 13Likes
post #1 of 35 (permalink) Old 05-03-2019, 07:54 AM Thread Starter
OCEdesigns's Avatar
First Name: Chad
Default First pass is too deep
I have not noticed this before but in this project it was my first attempt at milling Aluminum. The plate is 1/8" thick (0.125) and 18"x18" I set everything up to use Virtual Zero. I'm running V-Carve Pro 9.5
I set it to a maximum cut depth of 0.030 and the end mill set to maximum pass depth of 0.010 for a total of 3 passes. See pics
The problem is the first pass was 0.035! The next 2 passes were correct at 0.010 each. I ended up with 0.055 total depth. The total depth I was OK with because I had enough material thickness to work with but the initial pass of 0.035 caused the end mill to "Dig" in or be pulled down into the material which caused a few imperfections in the sign. I checked a few tutorials and they all have the Start Depth at 0.0. And I did set it up to use the material surface for starting point.
Any ideas why my first pass is going way beyond the set point? What am I missing?
Name:	CNC Pic 1.jpg
Name:	CNC Pic 2.jpg
Name:	CNC Pic 4.jpg
Name:	CNC Pic 3.jpg
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #2 of 35 (permalink) Old 05-03-2019, 08:01 AM Thread Starter
OCEdesigns's Avatar
First Name: Chad
The picture of the R is a test piece I tried after I made the sign and it did it again. (The R is actually from the sign. I just set it up separately on another piece of material)
post #3 of 35 (permalink) Old 05-03-2019, 08:31 AM
Pro4824's Avatar
First Name: Joe
Sorry I'm no help but at least you're not alone. My first aluminum cut did the exact same thing. I never did figure it out. Broke 2 bits, rebooted, recalculated everything and then it worked fine.
OCEdesigns likes this.
Pro4824 is offline
post #4 of 35 (permalink) Old 05-03-2019, 08:52 AM
UglySign's Avatar
First Name: Ronnie
Make sure you're using a coolant cutting Alum.
Some do get by on plain air others do WD40.
I hate the WD40 smell and the mess it leaves.
Actually surprised at the cost of the FogBuster
Pretty soon I'll be cutting alum but not looking forward to
giant mess that'll be left all around the machine.
When doing the Alum cut setup, wouldnt be just the same as you
normally would? just a less than thru cut?
Can that program do side-to-side cuts? They look better
than the spiral if paint filling.
UglySign is online now
post #5 of 35 (permalink) Old 05-03-2019, 08:59 AM Thread Starter
OCEdesigns's Avatar
First Name: Chad
I did the WD40 and it worked real well. I actually prepped the entire area pretty well to keep the mess as contained as possible. I can do the side to side cuts and have done that several times in wood. My only issue with this was the initial cut of 0.035 depth instead of the programmed 0.010 depth.
post #6 of 35 (permalink) Old 05-03-2019, 10:21 AM
Check your Safe Z and Home position settings.
Does the preview show the deep cut?
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #7 of 35 (permalink) Old 05-03-2019, 10:25 AM Thread Starter
OCEdesigns's Avatar
First Name: Chad
My Safe Z is set at 0.800
I didn't look to see if the preview shows it. I can check when I get home this afternoon.
post #8 of 35 (permalink) Old 05-03-2019, 10:38 AM
Your pic shows Safe Z at .2 - not .8
HJ
Detroit Burbs
post #9 of 35 (permalink) Old 05-03-2019, 10:40 AM Thread Starter
OCEdesigns's Avatar
First Name: Chad
You're right. My Home Z is .8 and Safe Z is .2
post #10 of 35 (permalink) Old 05-03-2019, 11:26 AM
beltramidave's Avatar
First Name: Dave
Is it possible that you forgot to recalculate your toolpath after setting your passes = 3? I have forgotten to do that on occasion after making a toolpath change. You could look at the gcode and see what it is being told to do on the first pass.
I would also recommend ramping instead of plunging to cut depth.
Dave
beltramidave is offline
Deep narrow slot question Giwannadothat General Routing 17 02-22-2014 05:41 PM
Plunge Routing Deep Mortises & Kick Back aronson General Routing 8 03-24-2012 07:41 PM
Routing deep mortise Dalec Portable Routing 17 04-27-2011 04:50 PM
3 pass mdf raised panel doors (bits?) cabinetal Router Bits - Types and Usage 7 06-28-2010 10:50 AM
How deep is to deep? jschaben Router Bits - Types and Usage 8 08-13-2009 10:50 AM
