Shark CNC 4D - Router Forums
 21Likes
post #1 of 11 (permalink) Old 05-14-2019, 11:43 AM Thread Starter
Default Shark CNC 4D
Hello Everyone,
I am brand new to the forum and excited to learn from you all! I just purchased a Shark 4D CNC machine and was wondering which router is the best for it.
Thanks so much!
moakes8033 is offline
post #2 of 11 (permalink) Old 05-14-2019, 01:09 PM
OCEdesigns's Avatar
First Name: Chad
Welcome here!
Nextwave recommends Porter Cable 890 series, or Bosch 1617 series routers. However if you can the water cooled spindle is a better option if you want it quiet!
I have the HD4 Extended and went the spindle way. Not only is it MUCH more quiet you can run a long time and not damage the spindle. The router will wear out much faster. I did a sign that was about 5 hours of milling time. I couldn't imagine having the screaming sound of a router going for that long!
MEBCWD, artman60 and moakes8033 like this.
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #3 of 11 (permalink) Old 05-14-2019, 01:54 PM
Air cooled spindle is good too. Not as much mess or worry about leaks.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #4 of 11 (permalink) Old 05-14-2019, 03:42 PM
difalkner's Avatar
First Name: David
Welcome to the forum, Mike! We like photos so post away - shop, tools, new Shark 4D CNC, projects, etc. - whenever you're ready.
David
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #5 of 11 (permalink) Old 05-15-2019, 07:50 AM
First Name: mary
marecat3 is offline
post #6 of 11 (permalink) Old 05-15-2019, 11:03 AM
Gaffboat's Avatar
First Name: Oliver
Welcome, Mike. I use the Bosch 1617 on my Shark because I like the ability to use a 1/2" shank bit if needed. I believe most spindles limit you to 1/4" shafts. My Shark is in an enclosure so the sound doesn't bother all that much, and I can carry on a conversation while it is running. Having said all that, Honest John's air-cooled spindle sounds appealing.
Gaffboat is offline
post #7 of 11 (permalink) Old 05-15-2019, 12:47 PM
Pro4824's Avatar
First Name: Joe
Welcome aboard Mike!!
My water cooled 2.2kw spindle accepts 1/2" shanks and is quieter than the dust collector and I can sit there and talk on the phone UNTIL the bit enters the wood.
An enclosure is your only option if you want true peace and quiet.
https://youtu.be/6nAlcHj7EKw
moakes8033 likes this.
Pro4824 is offline
post #8 of 11 (permalink) Old 05-15-2019, 06:05 PM
ger21's Avatar
First Name: Gerry
Most 2.2Kw spindles have ER20 collets, which can accept 1/2" shank bits. And they are more powerful than your Bosch.
https://www.ebay.com/itm/264323025353
Ger
www.cncwoodworker.com
ger21 is offline
post #9 of 11 (permalink) Old 05-16-2019, 10:34 AM
Gaffboat's Avatar
First Name: Oliver
Thanks, Gerry. That is good information to know.
Gaffboat is offline
post #10 of 11 (permalink) Old 05-17-2019, 01:16 PM
MEBCWD's Avatar
Welcome to the Router Forums Mike.
The HD series Sharks are limited to the smaller 1.5kw spindles because of the added weight, that is the size of the spindle Next Wave Automation offers. Theirs comes fully wired and ready to go but you can buy one and wire it yourself if you think you are capable of doing it and save about half the cost. I am using a Bosch 1617 on my Shark HD1 and it does a great job. The important thing to remember is you don't need to run your router at full speed. It will last a lot longer if you limit the speed of your spindle and adjust your feeds to the limits your machine will handle. I'm running mine around 16000 RPMs.
artman60 likes this.
MEBCWD is online now
CNC Shark Pro, wood router review mpientka CNC Routing 17 07-06-2015 09:52 PM
CNC Shark Pro Plus - Pros & Cons - Cans & Cannots Leighton Cook CNC Routing 1 08-15-2014 09:09 AM
Despite the fact that CNC Shark moves well manually in Jog mode, the machine fails arkadzi CNC Routing 7 06-22-2010 04:28 PM
