Tapered ball nose bit - Router Forums
 26Likes
post #1 of 17 (permalink) Old 05-21-2019, 05:09 PM Thread Starter
difalkner's Avatar
First Name: David
Default Tapered ball nose bit
One bit I don't have and need to get is a tapered ball nose. I plan to do some 3D carving soon and have some 1/8" and 1/4" ball nose bits but have been looking at 1/16" tapered ball nose bits.
Should I get 2, 3, or 4 flutes? I know stepover is the key on these and I'm certain I'll start out with conservative settings. As of right now I don't even have a project in mind so whatever I get will be like most bits in this area and I'll just make it work.
I don't want to spend $50 or more on this bit until I get comfortable with what I'll want. I know you get what you pay for but I've seen bits in the $20 range up to $35 and that's where I'd like to start. Probably 90% of what I cut will be Walnut, Maple, Cherry, etc.
Suggestions, please.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #2 of 17 (permalink) Old 05-21-2019, 05:44 PM
Pro4824's Avatar
First Name: Joe
JERRAY CNC Carving 4.82 Deg Tapered Angle Ball Tip Radius=0.5mm X 1/4" Shank Tungsten Solid Carbide HRC55 with TiAIN Coated Router Bits https://www.amazon.com/dp/B015C61XX4..._ldh5CbQ0TN6WM
Here ya go David.
I use it on wood and bronze, it does great on both!! $16
MEBCWD likes this.
Pro4824 is offline
post #3 of 17 (permalink) Old 05-21-2019, 07:25 PM Thread Starter
difalkner's Avatar
First Name: David
Thanks, Joe! I was actually looking at that one in the 1mm radius. Do I need to get the 0.5mm radius instead? Or should I get both...?
David
David
Romans 3:23
post #4 of 17 (permalink) Old 05-21-2019, 08:27 PM
Pro4824's Avatar
First Name: Joe
I like the .5 but I'll probably get the 1mm also.
difalkner and MEBCWD like this.
Pro4824 is offline
post #5 of 17 (permalink) Old 05-21-2019, 10:48 PM
MEBCWD's Avatar
I also have those in the 1/8" shank bits. Here is a link to the set but you can buy them individually. https://www.amazon.com/Package-Assor...eb_16336927011
difalkner likes this.
MEBCWD is offline
post #6 of 17 (permalink) Old 05-22-2019, 01:44 AM
First Name: Gerry
The Jerray 0.5 mm is an excellant bit. I use it a lot. My normal bits are 0.5mm TBN, 1/16" TBN, and 1/8" TBN for larger pieces. I almost always use a 8% stepover in Aspire when using TBN. With the Jerray, the surface comes out like glass.
https://www.routerforums.com/attachm...369691&thumb=1
TimPa, difalkner, MEBCWD and 2 others like this.
gkas is offline
post #7 of 17 (permalink) Old 05-22-2019, 09:43 AM
OCEdesigns's Avatar
First Name: Chad
I have used this same one but in 2MM. I'm going to buy the 1MM
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #8 of 17 (permalink) Old 05-22-2019, 10:11 AM
Pro4824's Avatar
First Name: Joe
So what bit do you use to cut the mirror circles with? Pcd Diamond?
Pro4824 is offline
post #9 of 17 (permalink) Old 05-22-2019, 10:14 AM
BalloonEngineer's Avatar
First Name: Richard
David, while the usual recommendation is 2 flute bits for most wood cutting, for the smaller tapered ball nose Ron Reed at PreciseBits recommends 3 flutes because the bits are quite a bit stronger, allowing a bit more aggressive feed rates. He has presented at our CNC User Group a couple of times, and is extremely knowledgeable. PreciseBits has some excellent tapered ball nose bits, and their shop is only two miles from where we usually meet. I also have and have used some of the import ones, and they are fine, but in my opinion, the PreciseBits ones cut a bit cleaner
For a project I am working on, I will shortly doing be some side by side testing, same design, same wood, different bits, so I hope to have a little more evidence as to whether my opinion can be substantiated.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is online now
post #10 of 17 (permalink) Old 05-22-2019, 10:46 AM Thread Starter
difalkner's Avatar
First Name: David
I'm certainly looking forward to that, Richard. I ordered the 0.5mm and 1.0mm Jerray bits to get started and will just go from there.
I did see a Yonico 4 flute bit at 1/16" and it looks pretty good at $24.95. Also saw an Amana in the same specs as the Yonico but it was $46.50 and I didn't want to spend that much right out of the gate.
Looks like I need to get a file ready, the bits will be here tomorrow!
David
David
Romans 3:23
Bull Nose Bit Help Needed onhillww General Routing 10 09-24-2012 08:43 AM
Selecting the router bit for a given application Chris_L Router Bits - Types and Usage 4 02-13-2012 09:49 AM
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 12:16 PM
Room divider finished jigger Jiggers Gallery 17 09-27-2011 12:05 AM
bit speeds, something to think about reible Router Bits - Types and Usage 0 10-19-2004 10:20 PM
