The "J" - Router Forums
 24Likes
  • 14 Post By Pro4824
  • 6 Post By Pro4824
  • 2 Post By RainMan 2.0
  • 2 Post By MEBCWD
post #1 of 10 (permalink) Old 05-22-2019, 03:57 PM Thread Starter
Pro4824's Avatar
First Name: Joe
Default The "J"
My Son did some work for the owners of The Joint BBQ in town and they asked if he could make a metal lighted sign like their J on the menu board and he said "sure!"
So here we go.......
Ya just never know what's gonna be next. 🙂
Pro4824 is online now
post #2 of 10 (permalink) Old 05-22-2019, 04:06 PM
OCEdesigns's Avatar
First Name: Chad
Simple yet very cool!! I like it.
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is online now
post #3 of 10 (permalink) Old 05-22-2019, 05:41 PM
Neat!!
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #4 of 10 (permalink) Old 05-22-2019, 06:25 PM
RainMan 2.0's Avatar
Very nice
Ok ,I never insulate
RainMan 2.0 is offline
post #5 of 10 (permalink) Old 05-23-2019, 10:29 AM
MEBCWD's Avatar
So I guess it is up to them to get an electrical box run to the location they want it mounted.
Neat project.
MEBCWD is offline
post #6 of 10 (permalink) Old 05-23-2019, 11:37 AM Thread Starter
Pro4824's Avatar
First Name: Joe
Neat project.
That might be the case if they would've had anyone else make this but we used led lights that run on 3 AA batteries. They can hang it anywhere or walk around with it lit up. 🙂
post #7 of 10 (permalink) Old 05-23-2019, 12:45 PM
First Name: mary
very nice
marecat3 is offline
post #8 of 10 (permalink) Old 05-23-2019, 09:29 PM
Thatís neat, as I didnít think those were led . Works really well for the sign
MEBCWD and Herb Stoops like this.
post #9 of 10 (permalink) Old 05-23-2019, 11:22 PM
MEBCWD's Avatar
You could also add a jack for a small transformer for when they do have access to a power plug. That way they wouldn't have to run it on batteries all the time.
Herb Stoops and OCEdesigns like this.
MEBCWD is offline
post #10 of 10 (permalink) Old 05-24-2019, 02:18 AM
If you use a transformer, it has to have a full rectivied output or the lights will flicker rapidly. The great thing about LED is that they don't heat up, so you can mount them in wood. I did a project some time ago with LEDs on batteries, so I found a battery holder for D cells, and wired them in series to give the proper DC voltage. Using rechargable batteries means you can run them for a long time, recharge quickly, and run again. A little microswitch somewhere inconspicuous lets them turn it off. Great little inside sign.
I'm thinking I saw some Christmas lights that had nice fat round globes about 1 inch across. I also know you can get "running" lights that seem to move in a line. That would be pretty cool too. We used to have a set of Christmas lights on a balcony overlooking the hillside below, they would change to eight different patterns. using a small controller. Drill 1/4 inch holes in a pattern and you have a pretty spectacular display. Just musing, as usual.
