Another CNC Router Design Completed - Router Forums
 17Likes
post #1 of 16 (permalink) Old 05-24-2019, 09:53 AM Thread Starter
HDVideo's Avatar
First Name: Ed
Default Another CNC Router Design Completed
Last weekend I started another CNC router CAD model and finished it up last night. My goal on this one was to keep the overall width to a minimum by tucking the Y ballscrews in as close to the frame as possible. I think this would be a reasonably rigid machine, within the limitations of aluminum extrusions, and not difficult to build once machined parts are in hand. The model was created with Fusion 360 and all major dimensions are driven by user parameters. Those include X Ballscrew Length, Y Ballscrew Length, Z Ballscrew Length and Gantry clearance height. Change any one of those and the model adjusts to reflect the new dimensions.
Specifications:
Size - Parameter Driven
Extrusions - 80/20inc. 40 Series. All extrusions are 80mm x 40mm
Aluminum Plates - 5/8" for all except the front end plates which are 1"
X & Y Profile Rails - 20mm
Z Profile Rails - 15mm
X & Y Ballscrews - 20mm
Z Ballscrew - 16mm
Stepper Motors - Drawn with NEMA 23 ClearPath Servos but mounts will also accept NEMA 34 Stepper Motors
Name:	Parametric CNC Router-1.png
Name:	Parametric CNC Router-3.png
Name:	Parametric CNC Router-2.png
Name:	Parametric CNC Router-4.png
difalkner, MEBCWD and beltramidave like this.
HDVideo is offline
post #2 of 16 (permalink) Old 05-24-2019, 10:12 AM
BalloonEngineer's Avatar
First Name: Richard
When are you going to start building it?
I do not want to critique, but I do have some suggestions for you to consider if you are actually planning to build a CNC like this in the future. They are things I thought about and designed into my machine (which is by no means perfect). They are just things that made sense to me. But only if you are interested, this looks like a nice clean design that would work well.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #3 of 16 (permalink) Old 05-24-2019, 10:23 AM
difalkner's Avatar
First Name: David
Very nice work, Ed! You are so far ahead of me in Fusion 360 it's not even funny. Great job and a good design.
Except for ease of access to the Y servos (or steppers) could they go on the back to get them out of the way in the front?
David
HDVideo likes this.
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #4 of 16 (permalink) Old 05-24-2019, 10:33 AM
UglySign's Avatar
First Name: Ronnie
Thats really sharp lookin Ed
Can the motors be on the backside or??
I think I'd get hung up on them or they'll be a good place to hang me hat.
HDVideo likes this.
UglySign is online now
post #5 of 16 (permalink) Old 05-24-2019, 02:39 PM Thread Starter
HDVideo's Avatar
First Name: Ed
David
Thanks for the comments, David. The last couple of designs I did had the steppers in the back and this one could easily be swapped. Unless I screwed up somewhere along the line, there is only one joint connecting the entire gantry to the right side rail car spacer, so deleting that joint and spinning the gantry 180 degrees would put them in the back. My thinking was the router could be placed closer to a shop wall in this configuration and the couplers would be easier to get to if they needed to be checked. If the steppers end up hanging out over the edge of a table, I can see where it could be a problem this way.
Ed
HDVideo is offline
post #6 of 16 (permalink) Old 05-24-2019, 02:45 PM Thread Starter
HDVideo's Avatar
First Name: Ed
I don't know if or when I might build this one. I currently have a Probotix Asteroid which is serving the purpose right now (particularly after replacing the Z assembly), so it may be a while. When I do decide to replace the Probotix, this one might be the way I go. I'm always open to critique and/or suggestions, so please, let me know what you have in mind.
Ed
HDVideo is offline
post #7 of 16 (permalink) Old 05-24-2019, 02:46 PM Thread Starter
HDVideo's Avatar
First Name: Ed
Yes, that would be an easy change to the design. Thanks for the comments.
Ed
HDVideo is offline
post #8 of 16 (permalink) Old 05-24-2019, 02:57 PM Thread Starter
HDVideo's Avatar
First Name: Ed
Here it is with the Y stepper motors in the back. I thought I had done the joints so that would be an easy change, but hadn't tested it. Kinda surprised it still worked after all the changes made along the way.
Name:	Parametric CNC Router-16.png
difalkner, MEBCWD and OCEdesigns like this.
HDVideo is offline
post #9 of 16 (permalink) Old 05-24-2019, 06:18 PM
difalkner's Avatar
First Name: David
I thought about it being able to set closer to a wall but then I also thought about those times when a board needs to hang over the end or you need access to that end and realized placing it against a wall has some drawbacks. Same thing with placing one side against a wall. I can get to about 90% of ours, 100% if I move a small stand, and have used every bit of that many times.
Good job - again!
David
HDVideo likes this.
David
Romans 3:23
post #10 of 16 (permalink) Old 05-24-2019, 11:11 PM
First Name: Richard
Suggestion # 1 Design for maintainability.
There are various parts of the machine that will need periodic maintenance, including the bearing assemblies for the linear rails. Visualize how much of the machine needs to be disassembled to access any of your bearing assemblies to clean, lubricate or replace them. This will need to be done at some point in time.
On my machine, I can remove the 4 screws on any bearing block and slide it off the end of the rail. Please excuse the state of my machine, I just disassembled and moved my machine from my old shop to a small shed on my new property. It is not fully recommissioned.
Y-axis: (my longest axis the way I am currently configured)
X-axis (along the gantry axis)
Z-axis
And yes, there are hard stops on each axis that prevent the any of the moving parts from sliding off accidentally.
Your design shows profile rails, the blocks on those usually have grease nipples, so that eliminates the need to remove them for lubrication, which helps, but they are all trapped on each end of the linear rail by structure, and quite a bit appears to be involved to remove one.
HDVideo likes this.
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 09:51 AM
Intro and question john spies New Member Introductions 20 12-08-2018 12:08 PM
cnc router 3d design software Benjamin M88 CNC Routing 8 08-17-2016 09:25 AM
