Wood base/stand for a cnc router table - Router Forums
 36Likes
post #1 of 28 (permalink) Old 05-26-2019, 03:55 PM Thread Starter
RainMan 2.0's Avatar
Default Wood base/stand for a cnc router table
Guys ,if a wood base was used in a climate controlled shop (not mine obviously) ,
would it expand and contract enough to cause issues if it were used as a base for a cnc router table?
Obviously you want to maintain everything perfectly level when a cnc router table has been secured to its base , which made me wonder if wood would cause issues .
But if I was to buy a Pro cncrouterparts machine , Iíd much prefer to build my own base , as it would be much heavier and sturdier than what they have to offer
Ok ,I never insulate
RainMan 2.0 is online now
post #2 of 28 (permalink) Old 05-26-2019, 06:10 PM
difalkner's Avatar
First Name: David
Are you talking about the stand, Rick? Ours is wood and in a climate controlled shop - no issues whatsoever.
David
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #3 of 28 (permalink) Old 05-26-2019, 06:39 PM
ger21's Avatar
First Name: Gerry
Generally, it shouldn't be a problem.
Wood moves very little along it's length (almost zero). Make sure it's sealed and painted well, and you shouldn't have any issues at all.
My router is almost 15 years old, and made entirely of wood, and is the same today as when I built it. It's in my garage, which gets down to freezing in the winter, and over 90F in the summer. I do heat it in the winter when I'll be working out there, but I don't keep it heated.
I'm building a new 4x8 machine which also will be almost entirely made of wood. I expect it to be as good or better than a CNCRP machine, with better performance.
Ger
www.cncwoodworker.com
ger21 is offline
post #4 of 28 (permalink) Old 05-26-2019, 10:29 PM Thread Starter
Pictures are always welcome
difalkner likes this.
post #5 of 28 (permalink) Old 05-26-2019, 10:50 PM
Bring up the thread that 4D did when he built his stand. Simple, strong, practical, and cheap.
RainMan 2.0 likes this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #6 of 28 (permalink) Old 05-26-2019, 10:59 PM
difalkner's Avatar
First Name: David
You can review the stand I built here - https://www.routerforums.com/cnc-rou...-router-2.html
David
kp91 and RainMan 2.0 like this.
David
Romans 3:23
post #7 of 28 (permalink) Old 05-26-2019, 11:01 PM Thread Starter
David
Forgot about that one . You did one heck of a job, and I would most likely copy the design .
kp91 and difalkner like this.
post #8 of 28 (permalink) Old 05-26-2019, 11:10 PM Thread Starter
I may not have worry about a stand , as I’m getting close to traveling to Alberta for the CAMaster.
I’ve just been having one hell of a time deciding what to do
kp91 likes this.
post #9 of 28 (permalink) Old 05-26-2019, 11:14 PM
MEBCWD's Avatar
Rick I think the only problem you would have if the wood stand was well built would be if it is supported well. Like my shop is on steel runners and the land is old farmland so it is constantly moving with heavy rains or dry times. I have two torsion beams mounted on my stand and then my CNC is mounted to the beams. I check it now and then and make any adjustments needed to level everything back up using shims. I knew that it would be a problem and this was the best solution I could come up with. I just consider it part of my maintenance routine and it only takes 5 to 10 minutes to make adjustments.
I still hope to get a CNCRP machine and I'll probably use adjustable supports on the stand so I can make adjustments to when needed.
MEBCWD is online now
post #10 of 28 (permalink) Old 05-26-2019, 11:30 PM Thread Starter
I wasnít aware you were a CNCRP fan to . I donít think you can wrong with them from what Iíve read over the years . Many happy owners at CNCZone also .
I talked with Cory on the phone before and found them very helpful
Fold down router table Gaffboat Table-mounted Routing 21 09-09-2018 07:41 PM
Router Table for Incra LS Positoner completed! Michael H Table-mounted Routing 35 03-19-2015 01:40 PM
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 12:33 PM
For Sale: RS 500 Router Table - routertabledepot.com sheridan Woodworking Classifieds 1 08-20-2009 10:51 AM
