Small text - Router Forums
 5Likes
  • 4 Post By honesttjohn
  • 1 Post By Gary Wiant
post #1 of 4 (permalink) Old 05-26-2019, 09:41 PM Thread Starter
First Name: Jeff
Default Small text
What's a reasonably small text that can be done? I've tried 1/4 inch text, 1/4inch 60 and 90 degree and 1/2 in 90.looks perfect on first pass,then goes back over and ruins it. I kinda like the straight cut look from the first pass.
jeffp60 is offline
post #2 of 4 (permalink) Old 05-26-2019, 10:55 PM
Go to a 30 or 60 degree bit but don't use the ones with the big ends. Stick with the shaft size. I use a 60 degree more than anything and don't cut deeper than .12 inches.
Also remember, the smaller the text the bigger chance for tear out. Time for a laser too!!!
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #3 of 4 (permalink) Old 05-27-2019, 12:14 AM
MEBCWD's Avatar
How are you trying to cut the text? Pictures?
MEBCWD is offline
post #4 of 4 (permalink) Old 05-27-2019, 10:03 PM
Gary Wiant's Avatar
First Name: Gary
Make sure your table is level & flat.
Make sure you are using an engraving 60 or 30
As said above, make sure the lettering isnt going too deep. Keep it around .1
Gaffboat likes this.
I'm here to learn about CNC routing & anything else I can pick up.
God bless
Gary Wiant is offline
Looking for small screws Potowner1 Tools and Woodworking 15 09-28-2015 09:55 AM
Seeking a chuck for small drill bits JFPNCM Tools and Woodworking 22 12-30-2014 01:26 AM
Trying my hand a making a small box Gaffboat Show N' Tell 16 10-27-2014 10:38 PM
Videos: Cutting small pieces Safely Gaffboat Tools and Woodworking 9 09-05-2014 08:44 AM
routing small pieces zxxer12 General Routing 9 03-21-2005 04:40 PM
