Anyone know why it does this? - Router Forums
 1Likes
post #1 of 18 (permalink) Old 05-28-2019, 01:34 PM Thread Starter
First Name: Jeff
Default Anyone know why it does this?
Using grble controller 3.61 because I can't get xp to install any java.
Board is level the lines are me sending cutter around/ back and forth. 60 degree .25 vcarve at .15 depth. It starts correctly then just k3ps going deeper?????
On the left it carved garden first ,then cut deep. The lower right small one was last one.it started at the apostrophe s, then a, then fairy garden.
The z axis numbers kept going higher each time it started a letter. Up to 147 with a low I think of 70ish.
jeffp60 is offline
post #2 of 18 (permalink) Old 05-28-2019, 03:39 PM
OCEdesigns's Avatar
First Name: Chad
Have you checked your G-Code? How are you setting your Z zero?
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #3 of 18 (permalink) Old 05-28-2019, 03:46 PM Thread Starter
First Name: Jeff
I think never mind. Looks like my t but might be loose.
jeffp60 is offline
post #4 of 18 (permalink) Old 05-30-2019, 07:13 PM Thread Starter
First Name: Jeff
Man, what a pain. T nut worked loose and of course not where I could fit my hand in. Dismantled z and x, rebuilt z . because it never ends,my lead connection kept letting go.(rubber tube) couldn't get the clamp tight enough for some reason. Then for same unknown reason it worked.
NOW, I noticed that the bit drags about an 1/8 maybe even 1/16 inch before z lifts .WTF? I run $h, move to project zero, reset zero,run file. Bit heads for first point and a moment later the z goes up. What / where should I start to look? Am I too close to top? Thinner paper for a spacer?
Table is level now. I was off .008 across x axis.
jeffp60 is offline
post #5 of 18 (permalink) Old 05-30-2019, 11:37 PM
BalloonEngineer's Avatar
First Name: Richard
Is this a Bob’s CNC ? In the Bob’s Facebook Group there are lots of Z-axis issues discussed. You might find suggestions there.
If it is a different machine, please post some pictures.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #6 of 18 (permalink) Old 05-31-2019, 09:16 AM Thread Starter
First Name: Jeff
No, its homebuilt. Don't think it will show up in pic.
jeffp60 is offline
post #7 of 18 (permalink) Old 05-31-2019, 05:40 PM
MEBCWD's Avatar
Might have to do with the post processor you are using. Could also be something in your design file.
What design software are you trying to use now?
Richard this is a picture of Jeff's CNC. It is a DIY sliding table CNC built using drawer slides.
MEBCWD is offline
post #8 of 18 (permalink) Old 06-01-2019, 06:58 PM Thread Starter
First Name: Jeff
Ever have one of those days you just know its not a good day to sharpen knives or clean weapons? Been that kinda week. Surprisingly , I just switched to writing paper as a gauge instead of the paper from 2 sided tape. Seemed to fix scratch at start up
jeffp60 is offline
post #9 of 18 (permalink) Old 06-01-2019, 08:03 PM
MEBCWD's Avatar
Actually that first move is probably a rapid move so if it is not lifting up before the move it might have something to do with your safe Z setting.
MEBCWD is offline
post #10 of 18 (permalink) Old 06-03-2019, 12:59 PM Thread Starter
First Name: Jeff
Mike safe z is .25
MEBCWD likes this.
jeffp60 is offline
