logic trace 2018 selecting the command lines and arcs - Router Forums
post #1 of 3 (permalink) Old 07-01-2019, 05:06 PM Thread Starter
First Name: stan
Default logic trace 2018 selecting the command lines and arcs
I traced out a diagram using lines and arcs and showed where I selected line and where i selected arc
I even put the cut part back on the diagram that I traced for a fit test
woodman12 is offline
post #2 of 3 (permalink) Old 07-01-2019, 11:47 PM
JOAT's Avatar
First Name: Theo
I do stuff like that the Luddite way. I lay out the exact size design on paper. Glue the paper to plywood. Rough cut it out, then send down to the line. Perfect.
If I want more than one, trace the original on wood, rough cut, glue the original to the rough cut. Rout around that, and have a master that I can affix wood to and rout out copies up the wazoo, all perfect copies of the original.
Gather the villagers, pitchforks, torches; we march at dusk!
JOAT is online now
post #3 of 3 (permalink) Old 07-02-2019, 07:06 AM
thanks for sharing Stan - the logic trace is a very interesting operation. you seem to put it to good use!
TimPa is online now
