How to cut plastic? - Router Forums
 26Likes
post #1 of 29 (permalink) Old 07-01-2019, 06:49 PM Thread Starter
MT Stringer's Avatar
Default How to cut plastic?
That's the question for the day. I have a big plastic cutting board. I would like to use the CNC to make several boards out of it.
I think it is high density polyethylene. White plastic. I think it is about 1/2 inch thick. I need to go out to the shop and take measurements.
Probotix Asteroid with the Bosch 1617.
I have both 1/8th and 1/4 inch upcut bits so if it is thicker than 1/2 inch, I will use the 1/4 inch bit.
The real questions are how fast/or slow do you cut. At the lowest router speed?
I hate to ruin the board if it melts, but if it does, I will be OK. Learning experience.
All advice and suggestions appreciated.
Thanks in advance.
MT Stringer is offline
post #2 of 29 (permalink) Old 07-01-2019, 07:09 PM
Pro4824's Avatar
First Name: Joe
https://youtu.be/SiLWI62N5pc
Interesting, I might have to try this myself.
Pro4824 is offline
post #3 of 29 (permalink) Old 07-01-2019, 07:18 PM Thread Starter
Thanks for the link. As much as I watch You Tube videos, I haven't tried to find any help there.
Actually, I have used my machine in over a year. I have had several medical issues and that has brought me to a complete stop. But, I am in a lot better health now and the energy has returned. Step one will be to fire it up and re home everything.
I had to search Router Forums to find my post asking how to set up different coordinate systems. I found it, and all is well. Several projects are waiting in the wings.
Thanks again.
post #4 of 29 (permalink) Old 07-01-2019, 07:25 PM Thread Starter
18 x 23 3/4 x 1/2 inch...and it is not flat!
post #5 of 29 (permalink) Old 07-01-2019, 08:04 PM
Pro4824's Avatar
First Name: Joe
Originally Posted by MT Stringer View Post
18 x 23 3/4 x 1/2 inch...and it is not flat! <a href="http://www.routerforums.com/images/smilies/frown.gif" border="0" alt="" title="Frown" >:-)</a>
1/2" is probably a little thick but I wonder if you can clamp it down and maybe use a heat gun to help it lay flat on it's own? Post some pictures when you get started on it and I'm glad to hear you're feeling better!! Joe.
MT Stringer likes this.
Pro4824 is offline
post #6 of 29 (permalink) Old 07-01-2019, 08:58 PM
Really glad you're feeling better now Mike. I had a similar experience and am only now getting back to decent health myself. My experience with cutting plastic is pretty limited, but I know the bit/blade quickly gets covered in plastic scraps, and if I go fast enough, it semi melts, but rarely sticks to the blade or bit.
DesertRatTom is online now
post #7 of 29 (permalink) Old 07-01-2019, 09:31 PM
I know Toolstoday and Precise bits have bits for plastic. Regular bits will leave tear out on acrylic, but the "for plastic" bits leave a smooth edge.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #8 of 29 (permalink) Old 07-01-2019, 10:01 PM
difalkner's Avatar
First Name: David
I use zero flute bits for acrylic but haven't tried to cut HDPE. I wonder how those would work? They sure work good on acrylic.
David
MT Stringer and beltramidave like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #9 of 29 (permalink) Old 07-02-2019, 06:48 AM
beltramidave's Avatar
First Name: Dave
David
+1 on zero flutes!
beltramidave is offline
post #10 of 29 (permalink) Old 07-02-2019, 07:48 AM
ger21's Avatar
First Name: Gerry
They are "O" (oh) flute, not zero flute.
Regular bits can cut acrylic fine. They just don't clear chips as well. If they are sharp, they will cut cleanly. Try climb cutting.
Ger
www.cncwoodworker.com
ger21 is offline
