First Two Sided Project - Router Forums
 18Likes
post #1 of 11 (permalink) Old 07-19-2019, 04:30 PM Thread Starter
MT Stringer's Avatar
Default First Two Sided Project
Well, got to start somewhere. I saw a workbench fence on the internet and thought to myself...I can make something similar. So here it is. One side is 1 5/16 and the other is about 5/8. Two dowels have been drilled through the center and a T track bolt inserted and screwed into a T nut that has been threaded into the underside of the dowel.
I am not sure what happened, but I broke a bit during the operation. I was in the office when it happened. But It will be OK. Just a little character added to the project! And I made the T Track a little too wide, but that won't hurt a thing.
Drilling the dowel centers was the challenge. Using a piece of plywood, I made a jig. With it fastened to the table, the cnc cut the opening for the dowel to fit in. That took numerous attempts with small changes made each time until I got the hole just right - not too tight; not too loose. Then I removed the jig, reset the z axis zero to the bed height, and ran another file that bored a recessed hole in the mdf 1/2 inch deep. Now with the jig fastened down on the bed, the dowels fit perfectly and protrude a little so I can add some support if needed.
Ready to drill! One file drills both ends with a 1/4 inch hole. Drill, flip, drill. Then a separate file opens up the hole on one end to 5/16 inch. The T nut threaded on like it was made to be there!
Now I have a fence that I can fasten to the holes on my work bench in just about any fashion. I have used a "redneck" version of this fence when assemblying cabinets by using a 2x4 and clamps so the carcase won't slide around on the table.
Hope you like it.
Name:	2019-07-17 16.32.35.jpg
Name:	2019-07-17 16.46.21.jpg
Name:	2019-07-17 16.57.11.jpg
Name:	2019-07-17 16.57.58.jpg
Name:	2019-07-17 17.07.45.jpg
Name:	2019-07-17 17.08.09.jpg
Name:	2019-07-18 20.33.33.jpg
Name:	2019-07-18 20.33.47.jpg
Name:	2019-07-18 20.34.16.jpg
Name:	2019-07-18 20.36.32.jpg
Name:	2019-07-18 20.37.08.jpg
Name:	2019-07-18 20.37.51.jpg
Name:	2019-07-18 20.38.10.jpg
MT Stringer is offline
post #2 of 11 (permalink) Old 07-19-2019, 10:43 PM
difalkner's Avatar
First Name: David
Good job, Mike. Keep up the good work!
David
MT Stringer likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #3 of 11 (permalink) Old 07-19-2019, 10:48 PM
Old_Tom's Avatar
Nice work Mike. Now if I only had a dedicated workbench.....or the room to have one!!
There's nothing like the smell of raw wood in the morning!!
Old_Tom is offline
post #4 of 11 (permalink) Old 07-19-2019, 11:07 PM
Pro4824's Avatar
First Name: Joe
Took me a few minutes to figure it out but I finally got it. Looks pretty handy!
Pro4824 is offline
post #5 of 11 (permalink) Old 07-19-2019, 11:52 PM
RainMan 2.0's Avatar
Neat idea Mike . Is this something you’ve seen before , or is this your concoction?
Ok ,I never insulate
RainMan 2.0 is online now
post #6 of 11 (permalink) Old 07-20-2019, 11:59 AM Thread Starter
This was my inspiration. Fortunately for me, I have everything needed to make one more, and maybe a third short one.
https://armor-tool.com/product/14%e2%80%b3-dog-fence/
RainMan 2.0 likes this.
post #7 of 11 (permalink) Old 07-20-2019, 03:47 PM
MEBCWD's Avatar
Should work just as good as the ones you used for inspiration.
They should be useful.
MEBCWD is offline
post #8 of 11 (permalink) Old 07-20-2019, 05:17 PM Thread Starter
Thanks Mike. I am using it now as a backstop.
TenGees likes this.
post #9 of 11 (permalink) Old 07-22-2019, 07:19 AM
very clever Mike! and now you have "2-sided" in your tool box...
TimPa is offline
post #10 of 11 (permalink) Old 07-22-2019, 10:04 AM
Honored Member
harrysin's Avatar
First Name: Harry
Well done Mike and you know how I love photo-shoots and yours is good. Why don't more members do shoots like that SHOWING HOW they made their project, descriptions are one thing but photographs can't be beaten.
Harry
harrysin is offline
