Ordering Avid Pro CNC - Page 3 - Router Forums
 221Likes
post #21 of 217 (permalink) Old 07-27-2019, 12:41 PM
Pro4824's Avatar
First Name: Joe
Originally Posted by difalkner View Post
I would get the 3kW over the 2.2kW. I doubt there's more than a couple of amps difference in what they pull and there's just something about MORE POWER that I love!!! :-)
David
I'm all for bigger if there's a benefit to it but if you can cut 3/4" birch at 150imp single pass with a 2.2kw and nema23 motors, I really don't see the need to spend the extra $$$
Unless you're running a cabinet shop.
https://youtu.be/7qgmGYUwK0M
RainMan 2.0 likes this.
Pro4824 is offline
post #22 of 217 (permalink) Old 07-27-2019, 02:15 PM Thread Starter
RainMan 2.0's Avatar
I was going to build it with Nema 34 . I read thereís less chances of having missteps etc with the larger steppers .
Ideally Iíd go with Servos, but thatís out of my budget
Ok ,I never insulate
RainMan 2.0 is online now
post #23 of 217 (permalink) Old 07-27-2019, 02:20 PM
Pro4824's Avatar
First Name: Joe
Sounds good although the only missteps I've had is when I've ran it into the bumpers during a bit change. (Yep, I'm too cheap to splurge on the $260 limit switches) 😉
Pro4824 is offline
post #24 of 217 (permalink) Old 07-27-2019, 03:02 PM
First Name: Gary
Sounds good although the only missteps I've had is when I've ran it into the bumpers during a bit change. (Yep, I'm to cheap to splurge on the $260 limit switches) 😉
On my present machine (self-designed and built), I'm using the high-priced Pepperl & Fuchs. However, on my first machine, I used the $18 for 5 Chinese cheapies.
Here's what I found:
Chinese are just as repeatable as P&F
P&F have a greater sensing distance
In a bypass (vs head on) sensing application, P&F pick up the target sooner
To maximize the Sensing distance with the Chinese, you have get the 18mm sensors (8mm sensing on steel) vs P&F, which are 12mm with 8mm sensing distance (about 1/4" dia. thinner). (I used the 18mm Chinese).
The P&F may last longer, but I do not have empirical evidence of that. In two years of use, the Chinese sensors never failed. I mechanically squared the gantry to the sensors. With the Chinese, homing on Y/slave axis was spot on every time.
Bottom line: IMO, cost is not an excuse for going bare.
Gary
The Old Man and the C - - -NC
gmedwards is offline
post #25 of 217 (permalink) Old 07-27-2019, 03:11 PM
First Name: Gary
I went with the NEMA 34s. No complaints. I suspect that if NEMA 23s were losing steps, there would likely be a mechanical issue somewhere, e.g., the linear rails not parallel, the table not coplanar and level., etc.
If you are familiar with the Saturn 2 welded steel machines, there are folks successfully pushing the much heavier gantry with NEMA 23s.
I like a beefier machine, so I use the 34s. That's just me, though.
Gary
post #26 of 217 (permalink) Old 07-27-2019, 03:36 PM
ger21's Avatar
First Name: Gerry
In our cabinet shop, we cut at 1200ipm with a 15HP spindle.
If you make the same cut at 300-400ipm, you'll double your tool life.
Also, a more powerful spindle will be cutting at a lower percentage of it's abilities, so it *should* last longer than a smaller spindle doing the same work.
I consider round chinese spindles to be disposable, so it's a minor issue.
Ger
www.cncwoodworker.com
ger21 is offline
post #27 of 217 (permalink) Old 07-27-2019, 04:53 PM Thread Starter
I’m trying to keep it one phase here lol, but I get your point
post #28 of 217 (permalink) Old 07-27-2019, 06:18 PM
Pro4824's Avatar
First Name: Joe
I've been running mine for a couple of years and only crashed maybe twice so I'll probably keep running it without sensors but it would be nice to finally get to click that ref all home button! 🙂
Pro4824 is offline
post #29 of 217 (permalink) Old 07-28-2019, 02:43 PM Thread Starter
lol, I done goofed with this response , as the VDF converts single phase to 3 phase I believe.
I’m dam near tempting to go with Avids VDF and spindle , but it sure seems pricey compared to other options.
But I guess you get what you pay for. I keep hearing about bearing failure with Chinese spindles , and I’m doubting the bearings are something you can change out yourself ?
post #30 of 217 (permalink) Old 07-28-2019, 03:00 PM
I got one of each. There is a marked difference.
MEBCWD likes this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
