Ordering Avid Pro CNC - Router Forums
 221Likes
post #1 of 217 (permalink) Old 07-25-2019, 10:22 PM Thread Starter
RainMan 2.0's Avatar
Default Ordering Avid Pro CNC
Well I should wait till my shops ready , but I feel I should purchase it now and assemble it this winter . I’m concerned about the exchange rate on the Canadian dollar ,and if plummets any further .
I measured my room a few times and although I’d prefer a 4x8 ,because of room constraints I’m going to special order a 4X5.
I’m keeping the X axis (the gantry) at 4’ , but adding a foot to the Y axis for a total of 5’ instead of 4.
As much as I’d like to , I’m not buying their electronics. I’ll buy a cabinet and build it myself , which I believe will be a beneficial learning experience, especially for future trouble shooting .
While I’m ordering the table, I have a few questions about other parts to get so they can ship together .
Auto Z and Corner Finding Touch Plate | Avid CNC | CNC Router Parts
Would you guys suggest using their touch plate , or are there better options ?
The expense doesn’t seem to bad .
Pepperl + Fuchs Proximity Sensor Kit | Avid CNC | CNC Router Parts
These sensors seem a bit expensive, and I’m thinking there’s a better option out there somewhere ? I don’t want mechanical stops .
100 mm Spindle Mount - CRP142-12 | Avid CNC | CNC Router Parts
I was going to order their optional tram plate, but I see it’s an option with the 100mm spindle mount . I’m still determined to use a water cooled spindle , so I may as well order this now for sure.
As for a base I want to make my own, so I can save that way also
Ok ,I never insulate
RainMan 2.0 is online now
post #2 of 217 (permalink) Old 07-25-2019, 11:29 PM
My opinions which are worth about as much as my 1/2 arse paintings. Just order the kit. Make your own stand if you wish. You want to cut or dabble? Saying that......
You need the touch plate for exact work. I still use playing cards but have the touch plate waiting to be hooked up.
I broke one proximity sensor. Cheapest I found was a similar one for about $5 cheaper than CNCRP. So I just ordered a couple from CNCRP.
Get the tram plate. Makes the spindle more rigid and adjustable. Personal choice for me was the air cooled spindle. Less muss and fuss. Just my opinion. But get a spindle of some kind.
That 4 x 5 will probably make most anything you will ever do -- and is expandable down the road. I'd buy their electronics (I'm lectronically limited), get it together, and start cutting as soon as possible. Their instructions and parts are pretty good and you will still learn what they are and what they do. You want to cut or play frustrated builder? The design engineer at my wife's place built his about the same time I was getting interested in CNC. His advice was buy whatever you can afford and screw the building from scratch --- unless your name is David Falkner.
Don't be penny wise and pound foolish.
Just my thoughts which don't mean a thing.
difalkner and RainMan 2.0 like this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #3 of 217 (permalink) Old 07-25-2019, 11:29 PM
difalkner's Avatar
First Name: David
We need to let Rick know his account has been hacked and compromised - someone impersonating him ordered a CNC. Next thing we'll see is insulation!
I'll play along... way to go, Rick! Btw, the 100mm spindle mount is for a 3kW spindle. A 2.2kW spindle uses 80mm. At least that's the way it normally goes. When's the arrival date?
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #4 of 217 (permalink) Old 07-25-2019, 11:34 PM
David
I don't think he's ordered it yet. He'll make some excuse not to I bet. lol
HJ
Detroit Burbs
post #5 of 217 (permalink) Old 07-26-2019, 12:09 AM Thread Starter
David
Good to know . I had 100 mm in my head for some reason . Actually I thought you were using a 100mm. Guess not
lol , I’m not taking any bets
post #6 of 217 (permalink) Old 07-26-2019, 02:22 AM
Scottart's Avatar
First Name: Scott
HOw, I go away for a day and Rick gets hacked. argggghhh..
RainMan 2.0 likes this.
Man with out Vision shall perish..women too!
Find more of our stuff on Etsy
https://www.etsy.com/shop/CreekWillo...platform-mcnav
Scottart is offline
post #7 of 217 (permalink) Old 07-26-2019, 03:36 AM
MEBCWD's Avatar
I'd say get the spindle mount w/tramming adaptor and the touch plate.
For the proximity/homing switches you will probably want to add connectors to the box to connect the cables to or at least use some kind of quick disconnects instead of wiring directly into the control board. There are all kinds of micro switches you can use, you just need to figure out how and where they need to be mounted. You will want to use shielded cable for the switches to help eliminate static problems.
You do have time to search for components but you do need to decide what control software you will be using so you get the correct boards and drivers for the steppers you decide to use. Doing your own electronics you need to remember you will have to configure the components for use with your chosen control software.
Looks like you will beat me to buying a new machine but I do have the insulation for the lower floor in my shop so if I hurry I might beat you to insulating.
MEBCWD is offline
post #8 of 217 (permalink) Old 07-26-2019, 07:07 AM
beltramidave's Avatar
First Name: Dave
I'm with John on buy the plug and play electronics, if you can. I built my own electronics, but that is what I do for a living..
As far as proximity sensors, I got mine from Automation Direct (online shopping). Also got my vfd and enclosure there.
A touch plate is definitely worth the money. Someday I will get John to use his...
Good luck with your build!
MEBCWD and honesttjohn like this.
Dave
beltramidave is offline
post #9 of 217 (permalink) Old 07-26-2019, 08:23 AM
difalkner's Avatar
First Name: David
I am using 100mm, Rick, and I have a 3kW spindle. I just didn't want to see you order a 100mm mount for a 2.2kW spindle, if that's what you're getting. You'll need the 80mm mount for the 2.2kW spindle.
David
MEBCWD likes this.
David
Romans 3:23
post #10 of 217 (permalink) Old 07-26-2019, 09:11 AM Thread Starter
David
Ok I was right with the 100mm mount as I want to get the same spindle your using . Any reason I shouldn’t go that big?
For 3D carvings ,maybe a 3kw is burning up more electricity than needed?
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests)
