Thought I was about done....... - Router Forums
 27Likes
post #1 of 24 (permalink) Old 08-19-2019, 02:04 PM Thread Starter
Default Thought I was about done.......
with the last bunch of big Polish eagles from the last festival. But 2 more custom orders just came in. Still have 1/2 doz smaller things to do yet plus 4 Polish family coat of arms.
MEBCWD, marecat3, TenGees and 4 others like this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #2 of 24 (permalink) Old 08-19-2019, 02:06 PM
RainMan 2.0's Avatar
Good for you John. Must be really enjoying retirement
honesttjohn likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #3 of 24 (permalink) Old 08-19-2019, 02:18 PM Thread Starter
Cutting is a lot more fun than tracking down, wiring, and trying to assemble parts hoping it all works.
MEBCWD and RainMan 2.0 like this.
HJ
Detroit Burbs
post #4 of 24 (permalink) Old 08-19-2019, 02:35 PM
Pro4824's Avatar
First Name: Joe
Those look really great John! But where's the paint? 😉
Pro4824 is offline
post #5 of 24 (permalink) Old 08-19-2019, 03:05 PM
.. wow!!!
Stick486 is offline
post #6 of 24 (permalink) Old 08-19-2019, 03:07 PM Thread Starter
That hurt. lol
They wanted wood. Customer is always (mostly) right.
HJ
Detroit Burbs
post #7 of 24 (permalink) Old 08-19-2019, 04:23 PM
I have no comeback for that one
except you left out insulating
John, how much time on the cnc does one take? Do you have a bit of cleanup , sanding etc?
post #8 of 24 (permalink) Old 08-19-2019, 04:59 PM Thread Starter
Loaded question, Rick. Depends on the cut depths of the rough cuts (or even if you do a rough cut), bit size, speeds, and stepover per cent. I don't run mine over 200-250 ipm just because that's my comfort level. It will go a lot faster. But 200 ipm means 200 ipm, not the slower speeds that the other machine does because of the acme screws. Sharp bits mean less fuzzies to clean up. Also depends on the type of material. Hardwood cuts smoother than softwood. Some of the pine blanks cut real smooth and others leave a lot of clean up. A good brush and sanding mop on a drill help a lot.
These took right at 3 hours each to cut. But I used the tool paths from the other machine, which could have added at least one pass (on the rough cut) to the CNCRP cut. A good sharp bit might even have eliminated the need for a rough cut. Then it would have been about an hour. Takes more time to mask and set up the names than it does to cut them. This thing cuts text almost as fast as you can write.
RainMan 2.0 likes this.
HJ
Detroit Burbs
post #9 of 24 (permalink) Old 08-20-2019, 10:16 AM
sreilly's Avatar
First Name: Steve
Seems the word is out.....good to be busy. You must be doing something right. Word of mouth is probably helping from those satisfied customers. Way to go John.
MEBCWD and honesttjohn like this.
sreilly is offline
post #10 of 24 (permalink) Old 08-20-2019, 10:17 AM
John I’m liking the different colours . Is the stain a different colour,or is it different woods?
I have to say those are really sharp ,and see why they generate repeat business
