Cutter with a point? - Router Forums
 11Likes
post #1 of 16 (permalink) Old 08-21-2019, 10:38 AM Thread Starter
First Name: Chuck
Default Cutter with a point?
I am trying to fine detail work, need a cutter with a point. Purchased two 60 deg. Freud cutters, neither has a point. Any suggestions?
rnubee is offline
post #2 of 16 (permalink) Old 08-21-2019, 10:47 AM
Pro4824's Avatar
First Name: Joe
Sounds like you're in the market for an engraving bit instead of V-bits.
CNC Engraving Bit, Enpoint 30 Degree Engraving Bit 1/8" 3.175mm Shank 0.3mm Tip Carbide V Bit with 2-Flute Grooves Metal Marking Conical Engraving Bit for Steel Brass Wood Aluminum MDF https://www.amazon.com/dp/B019K57LRA..._8IvxDbP5J4CJH
Name:	Screenshot_20190821-094508_Amazon Shopping-720x1480_1566398878718.jpg
difalkner likes this.
Pro4824 is offline
post #3 of 16 (permalink) Old 08-21-2019, 11:33 AM
ger21's Avatar
First Name: Gerry
CMT 858.001.11
https://www.amazon.com/60-Degree-V-G.../dp/B000P4NSYG
Ger
www.cncwoodworker.com
ger21 is offline
post #4 of 16 (permalink) Old 08-21-2019, 12:24 PM
Gene Howe's Avatar
First Name: Gene
https://www.amazon.com/Amana-Tool-45.../dp/B0025VK8PE
Herb Stoops likes this.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #5 of 16 (permalink) Old 08-21-2019, 07:05 PM
Harry's go-to resource...
https://www.banggood.com/search/engr...nc-router.html
harrysin likes this.
DaninVan is offline
post #6 of 16 (permalink) Old 08-21-2019, 07:15 PM
First Name: 4D
The point of cutters is to remove or cut material. It isn't hard to find V-bits with a sharp tip though.
4DThinker is offline
post #7 of 16 (permalink) Old 08-22-2019, 10:26 AM
sreilly's Avatar
First Name: Steve
I think Chuck gets the point. Not familiar with CNC but I didn't realize there were engraving bits.
sreilly is online now
post #8 of 16 (permalink) Old 08-22-2019, 10:29 AM
Honored Member
harrysin's Avatar
First Name: Harry
This one on a 1/2" shank is the finest in my collection and I can't imagine needing anything finer.
Name:	sharp bit0001.jpg
Harry
harrysin is offline
post #9 of 16 (permalink) Old 08-22-2019, 01:46 PM Thread Starter
First Name: Chuck
Default Re: Cutter with a point
Thanks for all the answers guys, I found out that evidently Freud doesn't make cutters with a point but Whitside does. I make a lot of small signs with lettering, that is why I need a point.
Thanks again.
rnubee is offline
post #10 of 16 (permalink) Old 08-22-2019, 04:25 PM
BalloonEngineer's Avatar
First Name: Richard
I find the spiral type v-bits are the cleanest cutting for me. These all have sharp points (the 30 will draw blood, DAMHIKT). The Whiteside 60 comes tor a pretty good point as well, for a traditional type 60.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
