Artpath wont open DWG files - Router Forums
 7Likes
  • 2 Post By difalkner
  • 2 Post By BalloonEngineer
  • 3 Post By ger21
post #1 of 6 (permalink) Old 08-27-2019, 02:27 PM Thread Starter
Question Artpath wont open DWG files
Hi all,
We just updated our Gerber Artpath from 4.0 to 6.5 and since the update I haven't been able to import any files into the program. We mostly use .dwg files and whenever I select the file I get the error message "Module GspCvtrFn.cpp Line 804 Error Loading GSP import filter" and then "OnErrorGspCvtr"
Has anyone else had this or a similar problem? If so, how did you fix it?
mnoga is offline
post #2 of 6 (permalink) Old 08-27-2019, 03:07 PM
difalkner's Avatar
First Name: David
Welcome to the forum! Add your first name to your profile to clear the N/a in the side panel and so we'll know what to call you.
Have you checked with the software tech support? Is there a plug-in that needs updating?
David
MEBCWD and RainMan 2.0 like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #3 of 6 (permalink) Old 08-27-2019, 07:41 PM
BalloonEngineer's Avatar
First Name: Richard
Are you sure you do not usually use DXF files? DWG files are usually the ones with dimensions, notes, etc. for prints. DXF files are usually the ones that contain just the geometry. According to their website, the software accepts DXF files, does not mention DWG files.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #4 of 6 (permalink) Old 08-27-2019, 10:12 PM Thread Starter
I definitely use .dwg. It's what I get from my designer, but it won't open either dxf or dwg files. I've tried exporting as pdf as well. But nothing seems to work. I reinstalled the software update and that didn't help.
I called and emailed tech support and they want to charge us $75, which my boss wants to avoid.
mnoga is offline
post #5 of 6 (permalink) Old 08-28-2019, 05:43 AM
ger21's Avatar
First Name: Gerry
How much is it costing your boss while he's trying to save $75???
Ask your designer what version the .dwg files are. And see if he can save as an older version.
difalkner, MEBCWD and Gaffboat like this.
Ger
www.cncwoodworker.com
ger21 is offline
post #6 of 6 (permalink) Old 08-28-2019, 09:19 PM
MEBCWD's Avatar
You might ask your question here https://gerbertechnology.vanillacommunity.com/
It is probably a missing plugin or something but might be a bad installer.
When you paid for the upgrade didn't they include some tech support? I think I would contact them and make sure.
If not it might be best to bit the bullet and pay for the tech support but it almost sounds like it might have been a bootlegged copy of the software and that is why it is not working and they what you to pay for support.
MEBCWD is online now
