Cutting Pockets in Kaizen Foam - Router Forums
 14Likes
  • 4 Post By HDVideo
  • 3 Post By CharleyL
  • 2 Post By HDVideo
  • 2 Post By HDVideo
  • 3 Post By HDVideo
post #1 of 9 (permalink) Old 08-31-2019, 10:59 AM Thread Starter
HDVideo's Avatar
First Name: Ed
Default Cutting Pockets in Kaizen Foam
I've been cutting Kaizen Foam inserts for a Rigid Mobile Gear Cart, which are available for various types of tool and gear boxes from KaizenInserts.com. This particular box can hold up to 5 layers + one in the lid of the box. The layer I'm cutting in this video would be the third from the bottom, although I made a 1/4" MDF shelf about 4" off the bottom rather than use the bottom two foam layers. The layer above this one holds a laptop computer, mouse and HDMI/USB adapter. The top layer holds a Yamaha audio mixer and wireless microphone. I've used the box on a couple of occasions so far and all seems to work well.
HDVideo is offline
post #2 of 9 (permalink) Old 09-01-2019, 11:58 AM
sreilly's Avatar
First Name: Steve
It would be interesting to see the "finished" product. Having that ability would be great for outreach astronomy for transporting mounts, eyepieces, and so on.
sreilly is offline
post #3 of 9 (permalink) Old 09-01-2019, 04:19 PM
difalkner's Avatar
First Name: David
Pretty nice, Ed. You can probably cut it at 250 ipm with no issue, though. Which bit is that?
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #4 of 9 (permalink) Old 09-02-2019, 07:54 AM
OCEdesigns's Avatar
First Name: Chad
Very cool!
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #5 of 9 (permalink) Old 09-02-2019, 09:58 AM
CharleyL's Avatar
First Name: Charley
For those interested in cutting foam without a CNC.
I found that electric kitchen carving knives work great for this, and it is my #1 choice whenever faced with the need to cut foam plastic or rubber of just about any density. I once cut a foam mattress to fit around the bulkheads and hull shape in a small yacht, then made a fabric cover for it to match the shape. Foam inserts for tool boxes are easy to size with one of these knives too, but for the semi rigid plastic foam, like used by florists, I found that a hot wire cutter works much better.
Charley
Central North Carolina
CharleyL is online now
post #6 of 9 (permalink) Old 09-02-2019, 08:23 PM Thread Starter
HDVideo's Avatar
First Name: Ed
I'll be using the box tomorrow night and will take a few pics at that time. Will try to get them posted in the next few days.
David
You're probably right about cutting faster, but since this was the first time I've tried this material, I was being conservative. I think they recommend a maximum DOC of 4x tool diameter, and I was going much deeper than that with no problems; 2.25" on those end cuts. The bit used was Amana Tool 46566.
Ed
difalkner and MoHawk like this.
HDVideo is offline
post #7 of 9 (permalink) Old 09-03-2019, 03:30 PM
MoHawk's Avatar
First Name: Bob
I was happy to see your post. A couple of years ago I made a post asking if any members had cut Kaizen on their cnc and didn't receive any replies. I need to make several pistols boxes and would like to use Kaizen with cutouts for the pistols.
Bob aka MoHawk & Gigawatt
CNCRP Pro4824, Aspire 10, Mach4
MoHawk is online now
post #8 of 9 (permalink) Old 09-03-2019, 04:00 PM Thread Starter
HDVideo's Avatar
First Name: Ed
It cuts easily on the CNC if you have the proper bit; downcut seems to work best. Also, cutting the profile of the pocket first, conventional milling, will help leave a clean edge provided you keep the foam from wrapping around the bit. You'll notice that happened several times in my video, but it was while the bit was away from the wall of the pocket. If it wraps like that near the wall, it can cause tearing and damage to the pocket wall. Don't ask how I know. lol
Ed
HDVideo is offline
post #9 of 9 (permalink) Old 09-04-2019, 06:40 PM Thread Starter
HDVideo's Avatar
First Name: Ed
Here are some pics of the Rigid Mobile Gear Cart with the three layers of Kaizen Foam inserts + one layer in the top. The bottom picture includes one of the smaller Rigid cases designed to sit on top of the Gear Cart with latches on the side holding everything secure.
difalkner, MoHawk and Herb Stoops like this.
HDVideo is offline
