120° / 130° / 140° etc bit angles - small diameter tho - Router Forums
 4Likes
  • 1 Post By MEBCWD
  • 1 Post By UglySign
  • 2 Post By subtleaccents
post #1 of 7 (permalink) Old 08-31-2019, 11:52 AM Thread Starter
UglySign's Avatar
First Name: Ronnie
Default 120° / 130° / 140° etc bit angles - small diameter tho
Anyone for a source that has 120° / 130° / 140° / 150° but small diameters?
Not the usual 1/2"dia., smaller. I'd like to make a few v-carved signs.
No 3D action just plain v-bitting being its simple.
Material used will be Sintra PVC & 30lb HDU.
Probably some Rowmark engraving stock @ 1/8" also.
So yea, it would have to be shallow in depth.
Thanks all
UglySign is online now
post #2 of 7 (permalink) Old 09-01-2019, 03:54 PM
MEBCWD's Avatar
I think what you will be finding with tip angles like that will actually be small drills for PCB drilling like this one with a 130 deg tip https://www.ebay.com/itm/NEW-34-1110...4AAMXQjq5Q91ri
Tip angles vary on these PCB drills form 90 to around 165 deg
Not sure if they would work for you but you would be using the actual cutting part of the bit so they might work.
Couldn't you use a flat tip v-bit and a flat bottom v-carve toolpath for the small lettering?
UglySign likes this.
MEBCWD is offline
post #3 of 7 (permalink) Old 09-03-2019, 04:26 AM Thread Starter
UglySign's Avatar
First Name: Ronnie
Thanks Mike
I have a good feeling we're passing this one up.
On the other hand why dont they have smaller diameter
wide angle bits? We have cpl listed above @ 1-1/4" & 2"+
for larger hdu signs, ya know the ones everyone sees.
MEBCWD likes this.
post #4 of 7 (permalink) Old 09-03-2019, 07:25 AM
ger21's Avatar
First Name: Gerry
As a general rule, the larger the size of the lettering, the larger the angle of the bit. Large angle bits don't work well with small letters, as the letters would be very wide, and very shallow.
If you are only cutting 1/16" deep with a 140° bit, the lettering would be almost 3/8" wide.
Ger
www.cncwoodworker.com
ger21 is offline
post #5 of 7 (permalink) Old 09-03-2019, 10:15 AM Thread Starter
UglySign's Avatar
First Name: Ronnie
Thanks G
Yes, was well aware of it. Some of these signs and elements
are at those sizes. A bunch of blocky lettering as well as skinnies.
For now, the project is on hold ($$)
post #6 of 7 (permalink) Old 09-08-2019, 11:06 AM
First Name: JT (Jim)
Have you tried Toolstoday.com? They have quite a selection of sign and engraving bits to choose from.
honesttjohn and UglySign like this.
subtleaccents is offline
post #7 of 7 (permalink) Old 09-16-2019, 11:28 AM Thread Starter
UglySign's Avatar
First Name: Ronnie
Yes TT is pretty good w/ what they have. I've found that some things they dont have and weeeelll
thats why I fig'd someone may know of another out there.
thanks acc
