Sign question - Router Forums
 16Likes
post #1 of 13 (permalink) Old 10-08-2019, 11:27 AM Thread Starter
Default Sign question
I have to make a two sided outdoor adress sign with a carved hunting and/or fishing theme that will be hung from an arm. I plan on using Corafoam (I got a lot of it) to make two signs with a backer board in between the layers. What's the best way to attach the Corafoam to the backer to withstand the elements? I'm going to try and paint it with acrylics (if I can find the paint by numbers) and then a couple coats of spar over the whole thing.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #2 of 13 (permalink) Old 10-08-2019, 01:41 PM
Gaffboat's Avatar
First Name: Oliver
Epoxy or Gorilla glue should work fine. Here's a good article from Coastal Enterprises on mounting HDU signs: https://precisionboard.com/signage/t...ard-hdu-signs/
Gaffboat is offline
post #3 of 13 (permalink) Old 10-08-2019, 01:50 PM Thread Starter
Thanx Prof Ollie
HJ
Detroit Burbs
post #4 of 13 (permalink) Old 10-08-2019, 05:52 PM
UglySign's Avatar
First Name: Ronnie
Be sparing w/ that glue. Too much and you has problems.
Use a light mist spray bottle of water also. You can't brush it on.
Hey J... have you ventured into Gold Leaf yet?
A book may seem expensive but goes a long way.
I bet one of those eagles would look quite $harp w/ it.
honesttjohn likes this.
UglySign is online now
post #5 of 13 (permalink) Old 10-08-2019, 05:59 PM Thread Starter
Have never tried it. Watched a you tube on it a long time ago. Polish people are pretty adement about their eagles. White, red, or natural material (like wood) are by far the most preferred. But you're right, I bet it would look sharp - even with just highlights.
UglySign likes this.
HJ
Detroit Burbs
post #6 of 13 (permalink) Old 10-08-2019, 06:35 PM
difalkner's Avatar
First Name: David
I have an upcoming project and will use gold leaf, just bought a 24k booklet. It's been years since I've used any gold leaf but I'm looking forward to using it again. Give it a shot on those eagles!
David
honesttjohn and UglySign like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #7 of 13 (permalink) Old 10-09-2019, 10:16 AM
First Name: mary
I am sure it will look great.
marecat3 is offline
post #8 of 13 (permalink) Old 10-09-2019, 12:25 PM
MEBCWD's Avatar
Sounds like a good choice of materials John. How big will the sign be?
MEBCWD is offline
post #9 of 13 (permalink) Old 10-09-2019, 01:05 PM Thread Starter
Probably around 20-24 x 16-20. Depends what all will go in it. Will be hung from something like a mailbox or real estate post.
HJ
Detroit Burbs
post #10 of 13 (permalink) Old 10-09-2019, 01:23 PM
MEBCWD's Avatar
You might check with the customer and make sure he doesn't have restrictions on how big the sign can be. I say that because they limit mailbox size and location here and also do not allow permanent signage in the right-of-way of the road.
MEBCWD is offline
