tekcel cnc 3x2 vse problem - Page 2 - Router Forums
 2Likes
post #11 of 12 (permalink) Old 10-16-2019, 11:53 AM
MEBCWD's Avatar
Originally Posted by johnnymacevo View Post
thanks what is this also?
Loose wire connection??
It is the connector between the motor and the end of the ball screw, it could be loose and slipping. If it has setscrews there might be 2 in each hole, one to clamp and the other to hold the first one in place. If it does have 2 then you need to remove the first one to tighten the clamping screw, then replace the second setscrew and tighten it against the first one.
MEBCWD is offline
post #12 of 12 (permalink) Old 10-16-2019, 12:03 PM
MEBCWD's Avatar
One other thing is feeds and speeds, are they within the limits of your hardware? You might be missing steps because you might be pushing your cuts harder than the machine can handle and causing the ball nuts to slip or jump.
MEBCWD is offline
