multi-profile, insert-style heads - Router Forums
 2Likes
post #1 of 13 (permalink) Old 11-12-2019, 11:23 AM Thread Starter
First Name: Brent
Default multi-profile, insert-style heads
I'm trying to learn more about CNC in general, but as someone who uses a spindle moulder all the time, I'm familiar with "euroblock" style cutter heads that allow you to buy one block, and then just replace the HSS knives for every new profile you want to do. Very cost effective and gives a superior finish. I'm wondering about the use of similar heads in CNC routers but can't find much. These are heads normally run on 1500lb shapers with 5HP+ so maybe they're considered "industrial" grade kit? Wondering if anyone here uses them or not and what their limitations are.
Thanks in advance!
B
timbrframr is online now
post #2 of 13 (permalink) Old 11-12-2019, 12:08 PM
UglySign's Avatar
First Name: Ronnie
Possible over at ToolsToday?
timbrframr likes this.
UglySign is online now
post #3 of 13 (permalink) Old 11-12-2019, 12:24 PM
I've never seen a CNC large enough to drive one of those and not torque out of shape or move from the intended cutting path. A gantry that could handle that much power would be massive.
post #4 of 13 (permalink) Old 11-12-2019, 12:33 PM Thread Starter
First Name: Brent
Here's an example using corrugated for up to 3" of profile.
https://www.guhdo.com/blog/corrugate...apter-for-cnc/
B
post #5 of 13 (permalink) Old 11-12-2019, 02:09 PM Thread Starter
First Name: Brent
Thanks!
They seem to have a lot of the carbide insert style heads but I didn't see the HSS tooling.
A guy I know has a 10hp, 3ph CNC router but it doesn't look as robust as you'd think.
B
post #6 of 13 (permalink) Old 11-12-2019, 02:41 PM
One of the other issues with using a molding head is that you are only using it to profile an edge or other words working in 2 D. I'm not sure what the advantage would be over just sticking with a shaper or molder. The real forte of CNC is controlling 3 axes or more.
post #7 of 13 (permalink) Old 11-12-2019, 08:50 PM Thread Starter
First Name: Brent
Curved work and speed is the big thing. Moulders take a looooong time to set up and don't do a lot of things like arch top raised panels etc. Shapers are great, but it's a manual process. Using cnc kit for 2D cabinetry is getting more common in the big shops all the time.
post #8 of 13 (permalink) Old 11-13-2019, 12:29 AM Thread Starter
First Name: Brent
Here's one over 4" in diameter with HSS replaceable knives. This must be for serious machines??
https://www.whitehill-tools.com/cata...d=143&c2id=144
B
post #9 of 13 (permalink) Old 11-13-2019, 02:05 AM
MEBCWD's Avatar
I think the bits you are talking about using would require large industrial-sized machines and possibly a true 5th axis depending on the application.
There are small insert bits made more for light production and hobby use. https://www.toolstoday.com/in-groove...rt-knives.html
There are other insert bits available more like what you are talking about but for smaller projects.
You could also have a good machine shop make the mandrel and custom profile inserts for you
MEBCWD is offline
post #10 of 13 (permalink) Old 11-13-2019, 07:40 AM Thread Starter
First Name: Brent
Hi Mike, thanks for weighing in. These heads are already commercially available for CNC routing applications (see link in previous post) so probably cheaper to buy vs have made. The nice thing about the HSS versions is that (since I have a profile grinder) I can grind my own knives which is handy.
Do you know what companies manufacture this grade of machine? I'll have to look up the 5fh axis.
B
