new toys - Router Forums
 2Likes
post #1 of 11 (permalink) Old 12-02-2019, 03:00 PM Thread Starter
Graham Prinn's Avatar
First Name: Graham
Default new toys
Hi folk's. So I went out and got me a new cnc router and new drivers and motors. I got the workbee 15/15 from bulk man that hasn't arrived just yet, maybe tomorrow or tonight. My drivers have arrived without instructions of course. Got closed loop drivers and motors, way to big for my machine but can used them for my second machine that I'll build. Nema 34 4.5NM huge. The drives and motors on the workbee seem so tiny, 175oz steppers.
Any way I have a question, other than mach3 which other control software would be good for closed loop set up? I do have mach3 but it's very old controls and looking to up date, mach4 is a bit pricey right now so looking to go the free or cheap way.
https://www.ebay.ca/itm/4Axis-4-5Nm-...72.m2749.l2649
The drivers I got.
Graham Prinn is offline
post #2 of 11 (permalink) Old 12-02-2019, 05:16 PM
Look into Linux. Beltramidave can help you with it.
MEBCWD likes this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #3 of 11 (permalink) Old 12-02-2019, 06:06 PM
difalkner's Avatar
First Name: David
The description says 'Mach3' board; does that mean it only works with Mach3?
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #4 of 11 (permalink) Old 12-02-2019, 07:25 PM Thread Starter
First Name: Graham
David
That's what I was wondering my self.
post #5 of 11 (permalink) Old 12-02-2019, 08:56 PM
PhilBa's Avatar
First Name: phil
Those motors are WAAAAY overkill for a workbee. A lot of people are running the workbee with GRBL on an arduino with something like DQ542s or even little TB6600s.
Visit my shop website.
PhilBa is offline
post #6 of 11 (permalink) Old 12-03-2019, 12:20 AM Thread Starter
First Name: Graham
I agree they are monsters compared to what's coming with the machine. https://www.ebay.com/itm/123758811267 that's what comes with the machine plus 175 oz steppers, I do have 3 425 oz stepper so I might use those for the x and y axis then use the 175 oz for the z, then use the monster set up for my next build. Which will be a 4x8 machine with R&P instead of screws.
I'll look into the GRBL.
I see the drivers are TB6600s I also have an extra 24 volt power supply if I need it to run the bigger motors.
I also have a 3 axis TB6600 so I'm wondering if I could use that for an extra axis like a rotary? That one doesn't need a break out board.
post #7 of 11 (permalink) Old 12-03-2019, 01:58 AM
PhilBa's Avatar
First Name: phil
The 175 oz steppers are a little on the light side though they might work ok running on 24V. I'd probably swap in the 425 oz ones. TB6600s will be fine for either motor. You will want a breakout board no matter what. Limit switches, estop, pause, cycle start, step/dir will all need connections. You could just get a wire terminal shield for an arduino mega - very inexpensive. I'd use 24V no matter which steppers you use.
PhilBa is offline
post #8 of 11 (permalink) Old 12-03-2019, 10:11 AM
BalloonEngineer's Avatar
First Name: Richard
Virtually no Nema23 sized steppers will run to their full potential on 24V. The optimum drive voltage is given by
V = 32 x sqrt(inductance)
Good low inductance steppers are around 2-2.5 mH and work with 48V, most sold in kits have much higher inductance, requiring 72-80V drive voltage. They will work with lower, but low drive voltage affects the speed they can run at, the drive current affects how much torque they have. Generally, with wood, you need decent speed to get the correct chip load at the rpms that routers or spindles turn. Generally want to get at or above 150ipm. Depending on the pitch of the ballscrews, may need higher rpm out of the steppers, hence the reason for higher drive voltage.
difalkner likes this.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #9 of 11 (permalink) Old 12-03-2019, 10:35 AM
PhilBa's Avatar
First Name: phil
True but it was a choice of 12 vs 24 that he already has. TB6600s are spec'd up to 40ish and 36V is the only other reasonable option. I was commenting on what he has, not suggesting he go buy more. We are talking about a workbee here which is going to flex a lot if you push it too hard - extruded AL CBeams and V wheels. Works great if you stay inside the envelope.
PhilBa is offline
post #10 of 11 (permalink) Old 12-03-2019, 12:19 PM Thread Starter
First Name: Graham
Man I just made a reply but the forum timed out on me and lost all I wrote, bugger.
Any way I have 2 24 volt ps and 2 60 volt that came with my 34 nema kit. Probably just use the 24 volts
I can fix the flex down the road with angle iron and change the bearings to metal and have them ride along the angle the thing I'm more worried about is the whip from the 8 mil lead screw. Why would anyone use a 3d printer lead screw for a larger machine is beyond me. I get that they are cheap but even a 3/8 multi start would be better and same price or not that much more.
