Metal Cutting Build Questions - Router Forums
post #1 of 6 (permalink) Old 01-22-2020, 08:08 PM Thread Starter
Default Metal Cutting Build Questions
New to the CNC world. Ive done lots of research and have an experienced buddy who is helping when able. However, there is a lot of information and different opinions. I have a background in metal fabrication, engine/car mechanics, some electrical knowledge, wood working/construction, etc. I understand this build will cost a decent amount, but Id like to keep it as cheap as possible my making what I can rather than buying.
I am looking to build a CNC table that can cut aluminum and steel up to 1/8" thick. Id like a cutting area of 4x4ft, but 3x3 or 2x4 could work as well. I understand that the bigger it is, the less rigid/more reinforcement needed.
My buddy mentioned building from epoxy type stuff for the forms/structure. Any thoughts on this? Links and information on how to do this is great.
What about table construction and materials? What parts should be reinforced/stronger materials and what would you recommend?
I believe Ill need liquid cooled motors and such, what motors, router, equipment would you recommend and why?
Billy Bee is offline
post #2 of 6 (permalink) Old 01-22-2020, 08:16 PM
Contributor of the Month
PhilBa's Avatar
First Name: phil
welcome to the forum. AL and Steel kind of push you in opposite directions. The machines people focus on here are more for wood cutting. A wood cutting machine can do some AL and plastic but not steel very well.
I suggest you check out CNCZone. It's a big and sprawling site but there are a number of sub-forums that can probably help you.
Visit my shop website.
PhilBa is online now
post #3 of 6 (permalink) Old 01-22-2020, 10:00 PM
BalloonEngineer's Avatar
First Name: Richard
Aluminum can be done on a sufficiently stiff router, sheet steel can be cut using a plasma, larger steel needs a mill. I have seen combo router/plasma, but separate machines will make life much easier.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #4 of 6 (permalink) Old 01-22-2020, 10:41 PM
Pro4824's Avatar
First Name: Joe
I agree, sounds like you'd be better off with a plasma table. Or at least an Avid cnc and add their plasma and water table to it.
Pro4824 is offline
post #5 of 6 (permalink) Old 01-24-2020, 08:39 PM
Welcome to the forum.
Sydney, Australia
jw2170 is online now
post #6 of 6 (permalink) Old 01-27-2020, 09:46 AM
First Name: mary
marecat3 is offline
