Absolute noobie to CNC - Router Forums
 9Likes
post #1 of 12 (permalink) Old 07-03-2020, 12:11 PM Thread Starter
rjunique's Avatar
First Name: Richard
Default Absolute noobie to CNC
What would be the easiest CNC software to learn for CNC? I intend to start with simple signs to begin with. I know very little about design software, although I have played with Sketchup very little.
I just purchased a Genmitsu CNC Router 3018-ProVer to see if I can learn to use it. Preferably free software. I do have Fusion 360 and Carbide Create, but having a hard time figuring it out. Thanks for any help you might be able to give me.
rjunique is offline
post #2 of 12 (permalink) Old 07-03-2020, 09:07 PM
difalkner's Avatar
First Name: David
When I built our CNC I began learning Fusion 360 and while the learning curve was steep at first I would have to say it leveled off quickly. Within a month I was able to produce just about anything I wanted. That was over 3 years ago and now I am far faster and create far better designs and toolpath strategy than I did when I started, but that's to be expected when you use something often.
Who are you watching for learning? I watched a lot of Lars Christensen videos to begin with but also found that the Fusion 360 forum is a very good one and folks will respond very quickly if you're asking for help.
When you say 'simple things', what exactly are you wanting to cut - flat work, 2.5D, 3D, engrave signs with lettering, etc.?
David
MEBCWD and RainMan 2.0 like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #3 of 12 (permalink) Old 07-04-2020, 08:16 AM
ger21's Avatar
First Name: Gerry
Vectric's various programs are by far the most widely used, and easiest to learn. Ton's of tutorials, and a very helpful user's forum.
MEBCWD likes this.
Ger
www.cncwoodworker.com
ger21 is offline
post #4 of 12 (permalink) Old 07-04-2020, 09:28 AM Thread Starter
rjunique's Avatar
First Name: Richard
David
To start with, only simple signs and engravings. Later, maybe get into more serious work>
difalkner likes this.
rjunique is offline
post #5 of 12 (permalink) Old 07-04-2020, 09:33 AM Thread Starter
rjunique's Avatar
First Name: Richard
Thanks for the lead to Lars Christensen videos.
rjunique is offline
post #6 of 12 (permalink) Old 07-04-2020, 10:25 AM
difalkner's Avatar
First Name: David
As much as I like Fusion 360 and as much as I have used it I have to say that it is mediocre, at best, for handling text. If your sign has a name or two names then you'll do fine. But if you're wanting to do a Bible verse, for instance, then you're better off with the Vectric line of products (although, those aren't free).
We bought Carveco, similar to Vectric, and it handles text just as easily as Fusion 360 handles complex engineering drawings. So when I do text then Carveco gets the nod - quick and easy.
David
David
Romans 3:23
post #7 of 12 (permalink) Old 07-04-2020, 12:00 PM
Gotta vote Vectric for us simpletons!!!
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #8 of 12 (permalink) Old 07-04-2020, 05:07 PM
Roland Johnson's Avatar
First Name: Roland
I started with carbide create because it came with the Shapeoko, and got to the point that between it and inkscape that I didn't want to do anything with it.Then I bought the Vectric V-carve Desktop and feel that it was the best thing since sliced bread. Affordable and eliminates the inkscape part, Check out the free 30 day trial and their forum also u-tube.
Roland Johnson is offline
post #9 of 12 (permalink) Old 07-04-2020, 05:14 PM
And....when you upgrade you get credit for the $$ you've already spent. Not to mention the more help available from other members since it's one of the most popular products used here.
HJ
Detroit Burbs
post #10 of 12 (permalink) Old 07-05-2020, 07:14 AM
First Name: Roland
Also with vectric watch Mark Lindsey's U-tube series for beginners a lot of what he shows is also good information for other programs but makes the vectric easy to learn
