Interesting idea for mounting spoil board - Router Forums
 10Likes
  • 2 Post By RainMan 2.0
  • 1 Post By honesttjohn
  • 2 Post By ger21
  • 3 Post By BalloonEngineer
post #1 of 8 (permalink) Old 07-12-2020, 12:24 AM Thread Starter
RainMan 2.0's Avatar
Default Interesting idea for mounting the spoil board
Just watched this video ,and Iíve never seen this done yet . By chance heís working on an Avid Pro , which is what I purchased. But Iím sure it can be implemented with any cnc that uses extruded aluminum for the bottom supports if a person wants .
Iím curious as to what Honest John and Ger21 think of this , as maybe itís more trouble than itís worth .
Starts at 11:00
Gaffboat and beltramidave like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #2 of 8 (permalink) Old 07-12-2020, 02:02 PM
Wondering what he's going to do for clamping??
I've got 7 - 3/4" 80/20 T-track running lengthways at various spacings. I'm going to put 1" pieces of either wood or MDF in between them, skim the entire work area, and do a grid. Then I can put material down anywhere on the bed and have access to a clamping area. If there'll be a profile cut I just have to put a piece of 1/8" whatever's on sale material under the model and pitch it when it's all chopped up. Should make the initial bed last quite a while. Right now I'm at the having the T-track installed (which was the most expensive). But I'm still using it regularly. Just watching how I place the cut material on the bed and putting something under the piece if it's going to have a profile cut, letting the clamping pressure hold it.
The "to do" list never gets shorter!!
RainMan 2.0 likes this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #3 of 8 (permalink) Old 07-12-2020, 02:29 PM
ger21's Avatar
First Name: Gerry
Actually, it seems like an easier method to attach it. But IMO, you'll want more support between the extrusions/2x4's, as it will sag between them.
I'd screw a layer (or two) of plywood first, and attach the spoilboard to that.
difalkner and RainMan 2.0 like this.
Ger
www.cncwoodworker.com
ger21 is offline
post #4 of 8 (permalink) Old 07-12-2020, 03:51 PM Thread Starter
In hindsight, I probably should have ordered mine with an extra cross member
post #5 of 8 (permalink) Old 07-12-2020, 06:05 PM
You can order a couple from Avid (or 80/20 since that's where they come from) - along with all the fasteners.
HJ
Detroit Burbs
post #6 of 8 (permalink) Old 07-12-2020, 06:09 PM
I can also rip down some stock 2 x 6's and 8's to fit too. Got plenty of Z height with this Avid machine compared to the Probotix.
HJ
Detroit Burbs
post #7 of 8 (permalink) Old 07-13-2020, 12:24 AM
BalloonEngineer's Avatar
First Name: Richard
Pretty much what I did 4 years ago. I slid carriage bolts into the slots in the 80mm x 80mm extrusions that support the spoilboard and used them to attach the 2x4s slightly proud. Much cheaper than t-nuts and no blindly trying to hit them with bolts. Milled the tops of 2x4s parallel to the X and Y axes.
Routed slots for t-track in spoilboard, 2 inch screws go through t-track into the 2x4s and hold spoilboard in place, no other screws. Looks clean.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #8 of 8 (permalink) Old 07-13-2020, 01:04 AM Thread Starter
Should have known that if anyone would have thought of this idea already , it would be you .
Nice job
