CNC router went down , bad wire. - Router Forums
 12Likes
  • 4 Post By Cncest
  • 1 Post By difalkner
  • 5 Post By BalloonEngineer
  • 2 Post By Cncest
post #1 of 8 (permalink) Old 07-12-2020, 12:48 PM Thread Starter
Default CNC router went down , bad wire.
The CNC spindle shut down half way through the Eagle head job. I found that the power cable from control box to spindle was bad. I replaced the wire and was able to save the job. Today I examined the old wire to see what was damaged. First thing I found was a random copper strand sticking out of the insulation. This wire was connected to the blue wire. See first pic. Then I stripped back the insulation and found the blue wire damaged and the green wire severed. See second pic. I replaced this wire with a heavier gage wire. So I hope this doesn't happen again.
Cncest is offline
post #2 of 8 (permalink) Old 07-12-2020, 01:23 PM
difalkner's Avatar
First Name: David
Hate that it happened but glad you found it. Good troubleshooting, Dan!
David
MEBCWD likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #3 of 8 (permalink) Old 07-13-2020, 12:30 AM
BalloonEngineer's Avatar
First Name: Richard
Should use high flex, shielded cable for spindle. Not cheap, but will last longer and prevent a lot of noise issues.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #4 of 8 (permalink) Old 07-13-2020, 01:07 AM
RainMan 2.0's Avatar
Nice catch . Was the damage at a pinch point ?
Ok ,I never insulate
RainMan 2.0 is online now
post #5 of 8 (permalink) Old 07-13-2020, 06:44 AM Thread Starter
The break was located on the X axis. Where the wire is constantly flexing during operation.
TenGees and RainMan 2.0 like this.
Cncest is offline
post #6 of 8 (permalink) Old 07-13-2020, 07:36 AM
sreilly's Avatar
First Name: Steve
What Richard said. Wire bending like that is always subject to wear. At least it was stranded wire which would last longer. But as mentioned there are better wires made for this type of work although they do cost more in the long run you have less downtime and less chance of grounding out possibly taking a control board with it.
sreilly is offline
post #7 of 8 (permalink) Old 07-13-2020, 11:48 AM
it appears that they got crimped somehow, but i could be wrong. you may want to investigate the area where they were to see if there is any binding, pinch points, etc...
oops, just read rainmans response, sorry!
TimPa is offline
post #8 of 8 (permalink) Old 07-13-2020, 12:15 PM
I don’t like the fact that the wires are tightly located in a jacket .
I added power windows to my 84 GMC ,used the factory internal door components, but built my own harness after seeing what GM was doing wrong .
They have all their wires taped tightly together , which causes them to bind each and every time they move .
So instead , I had my wires loosely sitting inside of wireloom , that way there was no binding , and I suspect I’d get a few million cycles before it would be an issue.
I did have a layer of tape around the wireloom to prevent the wires from coming out where the split is .
