Axiom Vs Nextwave - Router Forums
 7Likes
  • 1 Post By difalkner
  • 3 Post By BalloonEngineer
  • 3 Post By MEBCWD
post #1 of 6 (permalink) Old 08-06-2020, 01:09 PM Thread Starter
Question Axiom Vs Nextwave
I am looking for advice in selecting a new CNC machine. I have it narrowed down to either the nextwave HD510 or the axiom iconic 6. Can anyone with experience with thse two help narrow this choice? Am I missing a better product in a similar price range?
J
Jay Loftis is offline
post #2 of 6 (permalink) Old 08-06-2020, 02:49 PM
difalkner's Avatar
First Name: David
Welcome to the forum, Jay! Add your first name to your profile to clear the N/a in the side panel and add your location to your profile, as well.
We do like photos so show us your shop, tools, projects, etc. whenever you're ready. What sort of woodworking are you planning or doing with the CNC?
All I have heard about the Shark is how much flex it has although I understand they may have improved it somewhat. No experience with either machine other than a friend who has a Shark that's a few years old and his has a lot of flex. Others may chime in soon with other info for you.
David
RainMan 2.0 likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #3 of 6 (permalink) Old 08-06-2020, 04:31 PM
BalloonEngineer's Avatar
First Name: Richard
Curious how you narrowed it to those two. Is it because you saw them at a Woodcraft or Rockler? There are lots of brands and machines to choose from. The most important criteria is knowing what you want to do with it, size of pieces and materials you expect to work with. Nextwave are made in US and Axioms are imported, but as David said, Nextwave doesn't have a good history of being stiff.
My criteria for a good machine is stiff and fast. Rigidity is obviously key to precision and quality of cut. Proper chiploads in wood require fairly fast feed speeds at the speed of most routers or spindles. So both are key. Neither of those two brands are very speedy, but the Axioms I have seen are relatively rigid.
difalkner, MEBCWD and RainMan 2.0 like this.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is online now
post #4 of 6 (permalink) Old 08-07-2020, 10:01 AM
roxanne562001's Avatar
First Name: Roxanne
roxanne562001 is online now
post #5 of 6 (permalink) Old 08-07-2020, 05:56 PM
MEBCWD's Avatar
NextWave has improved its machine rigidity with the release of the HD510 but it still has noticeable looseness and still contains a lot of plastic in its structure. For a hobby machine, they are not a bad deal because they do come with Vectric VCarve Desktop so you don't have to look for a CAD/CAM package for project design. It does not come with a router or spindle normally.
They have had some problems with packaging the machine to limit shipping damage. There have been a few problems with the pendants also, and the computer control software they have is really problematic. NextWave has been saying for years that they were working to make their spindle controllable by gcode but so far they the only indication I have seen of that has be in the new post processor they have and that looks like it is still in the early testing phase.
The Axiom Iconic 6 is a tighter machine with more working area and does come with the spindle but not the design software. This would be my choice if these were the only choices I could choose from.
As Richard points out it really depends on what you really want to do with the machine. If you want to use it as a hobby machine then those two machines would probably be okay but if you would like to make some money in a small business then I would say look at other machines.
If you think you can build one from a kit then I would look at the Avid machines. They are well-engineered and they have a lot of happy customers. At this point in my life, I would go with an Avid Pro, years ago I might have designed and built my own.
So the bottom line is, what do you intend to do with a CNC?
MEBCWD is online now
post #6 of 6 (permalink) Old 08-11-2020, 09:58 AM
First Name: mary
marecat3 is online now
