Purchased a Chinese 6090 router - Router Forums
 33Likes
post #1 of 17 (permalink) Old 08-12-2020, 05:45 PM Thread Starter
kcortese12's Avatar
First Name: Karen
Default Purchased a Chinese 6090 router
I sold the Bobs E4 cnc I had. The gantry was not rigid enough to do any real carving. I work with a lot of hard wood, and that machine was jumping too much. I purchased a Chinese 6090 4 axis solid aluminum machine that is run with Mach3, 1500w water cooled spindle. The new cnc is still in it’s box, I did not assemble it yet because we had some foundation work done on the garage where my work shop is. I will be building a bench for it this week and hopefully be back in business next week. I will post some pictures after it is assembled. The work is 32” x 24” And am anxious to get it up and running.
It's always a good day when you wake up. Don't fret the small stuff, enjoy every minute of life you have.
kcortese12 is offline
post #2 of 17 (permalink) Old 08-12-2020, 07:27 PM
I have the 6040 3 axis model.
MEBCWD and kcortese12 like this.
Cncest is offline
post #3 of 17 (permalink) Old 08-12-2020, 09:02 PM
difalkner's Avatar
First Name: David
Nice, Karen. So 4 axis - it has a rotary axis with it? Or XYZ and Y has two steppers?
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #4 of 17 (permalink) Old 08-13-2020, 07:18 AM Thread Starter
kcortese12's Avatar
First Name: Karen
It has a rotary axis "A" that clamps to the board.
I can't wait to use it and have a lot to learn about Mach3.
difalkner and MEBCWD like this.
post #5 of 17 (permalink) Old 08-13-2020, 07:20 AM Thread Starter
kcortese12's Avatar
First Name: Karen
If you have a water cooled spindle, what coolant/antifreeze did you add to your water?
I was thinking of using the nontoxic kind that is used in RVs and campers.
post #6 of 17 (permalink) Old 08-13-2020, 07:28 AM Thread Starter
kcortese12's Avatar
First Name: Karen
I found that there is a huge problem getting technical customer service with the Chinese manufacturers.
The people I purchased it from do not know anything about assembly, or Mach3 configurations.
I had to do a lot of research for the right configurations.
There is a lot of information on the 6040 CNC but nothing on the 6090 CNC.
I guess this is a new model.
We are going to re-face my kitchen cabinets and needed a large work area to run some flourishes into my kitchen cupboard doors and drawer fronts.
MEBCWD likes this.
post #7 of 17 (permalink) Old 08-13-2020, 07:37 AM
For cooling, I use a 5 gal bucket filled with 1 gal RV nontoxic antifreeze plus 3 gal distilled water.
I believe the only difference between 6090 and 6040 is the table size.
Cncest is offline
post #8 of 17 (permalink) Old 08-13-2020, 07:41 AM
difalkner's Avatar
First Name: David
I do the same as Dan for ours, Karen. Except I have a 7 gallon container with 4 gallons of distilled water and 1 gallon of RV antifreeze. I also added the silver microbial strip. My pump has a filter on the inlet side and everything goes through a radiator with cooling fan.
David
kcortese12 likes this.
David
Romans 3:23
post #9 of 17 (permalink) Old 08-13-2020, 08:07 AM
sreilly's Avatar
First Name: Steve
Looking forward to some pictures.
sreilly is offline
post #10 of 17 (permalink) Old 08-13-2020, 08:24 AM
First Name: mary
look forward to seeing pictures
marecat3 is offline
