Vacuum table material (what type of MDF?") - Router Forums
 3Likes
  • 2 Post By honesttjohn
  • 1 Post By TimPa
post #1 of 8 (permalink) Old 09-17-2020, 06:57 AM Thread Starter
First Name: Mark
Default Vacuum table material (what type of MDF?")
Reaching out to see what you are using for your vacuum tables. If you dont use the correct MDF you loose, or dont get good vac. Any recommendations of what you are using and where to purchase. I am in MA
Marko63 is offline
post #2 of 8 (permalink) Old 09-17-2020, 08:03 AM
MDF has a finish coat on it. Skim that off and it should work.
difalkner and Gaffboat like this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #3 of 8 (permalink) Old 09-17-2020, 09:32 AM
how well does UHMW type material...
Stick486 is offline
post #4 of 8 (permalink) Old 09-17-2020, 01:08 PM
if your vac is less than super strong, you may consider ULDF. some mdf's are not so porous.
as John mentioned, you want to skim off one face, flip it over and glue it down, run the vac to hold it down for an hour or so. then paint the edges to seal them off. then run your spoilboard cut program to skim it off, and level it off.
UglySign likes this.
TimPa is offline
post #5 of 8 (permalink) Old 09-17-2020, 07:47 PM
ger21's Avatar
First Name: Gerry
Depends on the pump(s) you are using.
We use regular old MDF, with our two 10HP Becker pumps.
If you are using a vacuum cleaner motor, you might want lightweight MDF.
Ger
www.cncwoodworker.com
ger21 is offline
post #6 of 8 (permalink) Old 09-18-2020, 07:30 AM
First Name: Ray
Default Vacuum Table Material
I also live in MA (South Shore) and I purchase Ultralight MDF from my local lumber yard. They carry both the lightweight and traditional weight MDF. The Ultralight is much more porous and it did not require a surface skim.
rayk2 is offline
post #7 of 8 (permalink) Old 09-21-2020, 07:26 AM Thread Starter
First Name: Mark
Default more details
WE are running a 25hp sullair pump, MDF has been fly cut top and bottom, and all edges and unused area of the 5'x10' sheet have been sealed with (3) coats of polyurethane. My issue is when I purchase locally the mtl is always different sometimes its dark like a clip board and will not allow vacuum through it. I'm looking for mtl that is lighter in color and about 1/4" thick to use over the spoil board. Have had great luck in the past but now I am struggling to find the same type of MDF. When the material that worked was ordered it was ordered as "MDF" now when I go to re-order I cant get the same material and the vendor doesn't have record of exactly what we received. Its been a couple of years since we received that good stuff. I was hoping someone out there was doing the same process and had a source for their MDF with specific material details.
Thanks,
Mark
Marko63 is offline
post #8 of 8 (permalink) Old 09-21-2020, 07:21 PM
ger21's Avatar
First Name: Gerry
Ask for super refined mdf.
Are you trying to pull vacuum through both the spoilboard and a sheet of 1/4" MDF? 1/4" MDF is much more dense than 3/4".
Ger
ger21 is offline
