ready to give up 3018 - Router Forums
 3Likes
  • 2 Post By MEBCWD
  • 1 Post By BalloonEngineer
post #1 of 7 (permalink) Old 10-15-2020, 05:42 PM Thread Starter
First Name: Michael
Default ready to give up 3018
I have: 3018, Candle and USGS, CAMBAM generated gcode from AutoCAD2020 DXF drawing.
PROBLEM:
1. I don't know how to adjust depth of cut.
2. I have Gcode for a two inch diameter circle. Candle set for inches. The resulting cut is 1/8 diameter circle. It does the same on UGCS.
3. I cant find out why.
4. Thanks in advance
WM4MM is offline
post #2 of 7 (permalink) Old 10-15-2020, 08:05 PM
Smile
PROBLEM:
Welcome to the forum.
Sydney, Australia
jw2170 is online now
post #3 of 7 (permalink) Old 10-15-2020, 08:15 PM
old55's Avatar
First Name: Ross
Ross,
old55 is offline
post #4 of 7 (permalink) Old 10-15-2020, 09:08 PM
Forum Moderator
difalkner's Avatar
First Name: David
Welcome to the forum! Add your first name to your profile to clear the N/a in the side panel and so we'll know what to call you. Add your location to your profile, as well.
To better help you, we're probably going to ask for more info on your setup and machine but I see you aren't online right now so maybe others will chime in soon by the time you are back online.
We do like photos so show us your shop, tools, projects, etc. whenever you're ready. What sort of woodworking are you planning or doing with the CNC?
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #5 of 7 (permalink) Old 10-15-2020, 10:21 PM
MEBCWD's Avatar
Welcome to the Router Forums.
Try editing the gcode in notepad. Add a "G20" to the beginning of the gcode, that tells the file measurements are in imperial.
difalkner and Semipro like this.
MEBCWD is offline
post #6 of 7 (permalink) Old 10-16-2020, 06:44 AM
BalloonEngineer's Avatar
First Name: Richard
Your 3018 has a GRBL controller, which is mm native. Modern versions of GRBL should properly interpret G20/G21 commands, but it is probably best to use a GRBL mm post processor. You can design in inches, you CAM should be able to do the conversion for you. The depth of cut, as well as many other parameters (bit size, feed rate, spindle rpm, cutting inside/outside/on the line, ...) are all defined when you create toolpaths in your CAM software before exporting the toolpaths into g-code.
You need to learn and understand the entire process to go from a design to cutting on the CNC, it is not draw push a button and go.
difalkner likes this.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #7 of 7 (permalink) Old 10-16-2020, 07:56 AM
sreilly's Avatar
First Name: Steve
Welcome to the forum Michael.
sreilly is online now
