New CNC build using 80/20 extruded aluminum - Page 3 - Router Forums
 4Likes
post #21 of 47 (permalink) Old 02-08-2011, 12:17 AM Thread Starter
Noob's Avatar
First Name: Paulo
So you plan on mounting the 3030 on top of a table/bed without feet, is that correct? I found one like you are talking about I think (see attached pic).
That build is here: FandZ's 80/20 and nearly completely bolt together CNC build LINK
By the way, I did see some that used 4" CRS on a 3030 on the Y-axis so it might not be a problem on that axis after all: 8020 DIY CNC - Full Motion Test Youtube LINK
And his build thread can be found here: CNC Wood Router Project Log LINK
Noob is offline
post #22 of 47 (permalink) Old 02-08-2011, 06:34 PM
Yes that is what I was thinking. I want to build cnc with about a 50"x65" cutting area. And just trying to plan it out a little before hand so I don't waste to much material, money, and time. I'm glad I found this sight and thanks again for all the help!!!
mouch is offline
post #23 of 47 (permalink) Old 02-19-2011, 10:06 AM
Default Leadscrew Nuts
Noob, you have a really fine looking machine. What type of nuts are you using on your leadscrews to help prevent backlash?
iplay1515 is offline
post #24 of 47 (permalink) Old 02-19-2011, 07:27 PM
First Name: Larry
Did you say that you have the plans in a PDF format ?
woodie26 is offline
post #25 of 47 (permalink) Old 02-21-2011, 02:11 PM Thread Starter
Noob's Avatar
First Name: Paulo
I'm using these that are made out of delrin and have the hole pattern to match the 80/20 extrusion: 1/2-10 ACME Nut, 5 Start
[CRP109-00] LINK
Some prefer the Dumpster CNC, but if you use those you'll have to figure out a way to mount them. That wouldn't be difficult, but just mentioning that they don't bolt right up. Dumpster CNC ACME Anti-backlash Leadnuts LINK
Noob is offline
post #26 of 47 (permalink) Old 02-21-2011, 02:28 PM Thread Starter
Noob's Avatar
First Name: Paulo
I'll have to clean them up a bit because I've tweaked it a time or two.
Got the top on, but have to figure out what I'm going to do about a spoilboard: DIY CNC router controlled with XBox 360 controller LINK
Not sure if I want to use T-Slots on the spoilboard or put a couple rows and columns of holes with 1/4-20 tee nuts to hold the wood down.
I've got some of these from Amazon, and I may use them instead. 1/4"-20 Hurricane Nuts LINK
Noob is offline
post #27 of 47 (permalink) Old 02-23-2011, 01:41 PM
davidbarr's Avatar
First Name: David
Every one needs to check out Noob's website. It has the best step by step router build I have seen thus far.
No man e'er was glorious, who was not laborious.
Benjamin Franklin
I have no special talents. I am only passionately curious.
Albert Einstein
A wise monkey never monkeys with another monkey's monkey.
My Old Man
Boy I don't owe you nothin but a butt whoppin and that bill is long overdue!!!
There again My Old Man
davidbarr is offline
post #28 of 47 (permalink) Old 02-27-2011, 04:18 PM Thread Starter
Noob's Avatar
First Name: Paulo
Thanks for looking
It is a great idea to look at those step-by-step instructions because it can save you some time on assembling and dis-assembling; also they clarify some confusing parts of the build.
If you look at the attached pic, you will notice that I forgot to put the t-nuts into one of the extrusions, and also the bearing block is on the wrong extrusion.
That part of the assembly is an example that wasn't very clear. Directly behind where the t-nuts go, there are 2 screws that attach the 2 extrusions perpendicular to each other. In other words, in that pic, you see a vertical and horizontal extrusion attached like a "T", and a screw attaches those together. Then the t-nuts go behind those screws and the purpose of the t-nuts is to attach the motor mounts.
Sorry if that explanation is confusing, but you can see how it is supposed to be in the next pic.
Name:	Oops time 2 disassemble.jpg
Name:	On table.jpg
Noob is offline
post #29 of 47 (permalink) Old 03-01-2011, 10:25 PM
bheller's Avatar
First Name: Barry
Default Thanks
I'm new to the site and was lurking around and found your thread and your site. Thanks for posting the vids. I have the same kit (bought it over 8 months ago). I'm just now getting the time to build it and the edrawings do leave a little to be desired. I understand better after watching. Thanks again.
Barry
bheller is offline
post #30 of 47 (permalink) Old 08-05-2011, 03:54 PM
First Name: Ron
Send me the plans also if you can. Ive been looking a few and yours looks best so far
Longboard is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.routerforums.com/cnc-routing/24959-new-cnc-build-using-80-20-extruded-aluminum.html
Posted By For Type Date
iB::Topic::Stock duplicator? This thread Refback 02-10-2011 10:12 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Build your own CNC cdndave CNC Routing 9 08-31-2010 12:20 AM
looking to build a cnc router thomas mahaffey CNC Routing 5 03-16-2010 07:52 AM
extruded aluminum stock brownie58 Table-mounted Routing 6 11-24-2009 10:36 PM
Self build cnc wood routers perseo CNC Routing 3 10-05-2009 12:21 AM
Planning CNC build Joework CNC Routing 4 04-23-2009 01:27 PM
