New CNC build using 80/20 extruded aluminum - Router Forums
 4Likes
post #1 of 47 (permalink) Old 11-30-2010, 03:05 PM Thread Starter
Noob's Avatar
First Name: Paulo
Talking New CNC build using 80/20 extruded aluminum
Even though I don't know jack about electronics, I've embarked on a journey to build a CNC. I've looked at different plans for some time using MDF or plywood, but I've read a few threads about not using wood for the main structure (such as Check twice!'s build: New-build-cnc-router )
I even bought 2 DIY plans, one for a Rockcliff and the other for a Solsylva. Instead I'm going the Erector-set route and buying modular parts and extrusions. I think the most challenging part will be the electronics/software. I'm sure I'll be asking questions and hope I'll get help from time to time. I'm on the CNCZone, but that place is like a maze trying to sort through it sometimes.
The useable area is about 2ft x 3ft, and I think it will cost about $1,700. That is cheaper and have a larger working area than Rockler's smallest CNC I believe.
Most parts are from CNCRouterparts.com, and my electronics are from Finelineautomation.com since they had $50 off for Black Friday.
Basics:
Electronics: Gecko G540 pushing 3 High-torque Nema 23 380 oz-in stepper motors finelineautomation 3 Axis Electronics Kit
Mechanical: Using Linear carriages that are basically ABEC 7 rollerskate wheels that ride on 1/4" thick cold rolled steel flatbar: cncrouterparts mechanical parts
(also purchased all necessary mechanical parts from them).
And the leadscrews are 1/2-10 5-start ACME threaded rod McMaster #98940A627
The 80/20 1530 & 3030 extrusion (1 1/2" x 3" & 3" x 3") is from the 80/20 Garage sale on Ebay. 8020inc
I'll be using my Porter Cable 690 router motor for the spindle.
For a general idea of what it will look like see this build: glacialwanderer
By the way, Fineline sells complete kits including all holes drilled in the extrusions and flatbar, but I'm saving money buy doing it myself.
I still need to buy:
ACME rod
Cold rolled steel flatbar
Mach 3
Emergency Stop
Limit switches
Wire/cable
Fasteners/hardware
Wish me luck
Noob is offline
post #2 of 47 (permalink) Old 12-23-2010, 12:26 AM
Welcome to the RWS forum
post #3 of 47 (permalink) Old 01-02-2011, 01:19 AM Thread Starter
Noob's Avatar
First Name: Paulo
I bought the cold rolled steel flatbar cut to length from Metal Supermarkets LINK, but since they have a Dallas location, I didn't have to pay for shipping since I picked it up in person.
I cut all the aluminum extrusion to length. Now I have to drill some holes in both the 80/20 and the flatbar, tap a few ends of the 80/20, then I can start to assemble them.
I still need to buy a few corner pieces and joint plates to stiffen up the joints, but other than that, I have pretty much everything now.
Here is a vid of me bench-testing the steppers: X,Y,Z stepper test LINK
And here is a vid of me trying out the e-stop: Testing E-stop LINK
Oh yeah, I bought a wired XBox 360 controller (for Windows) and installed the XBox 360 plugin for Mach 3. I now have a pendant to move the X, Y and Z around with it. I don't have all of the buttons mapped yet, just the X, Y, and Z. I plan on mapping one of them for the auto-zero function.
Noob is offline
post #4 of 47 (permalink) Old 01-26-2011, 03:09 PM
First Name: Trevor Walsh
This is sounding pretty awesome, what CAM software are you using to run your machine?
Trevor Walsh is offline
post #5 of 47 (permalink) Old 01-26-2011, 03:57 PM
dovetail_65's Avatar
First Name: Dovetail
I love the wireless 360 controller, I couldn't live without it now! Why did you go wired?
dovetail_65 is offline
post #6 of 47 (permalink) Old 01-28-2011, 11:06 AM
Default ext 80/20 cnc
Nice build, where did you use the 3'x3'? Is it for the y axis.
mouch is offline
post #7 of 47 (permalink) Old 01-28-2011, 12:03 PM
Default New CNC build using 80/20 extruded aluminum
That little bit of 8020 ext cost $584.00 ?
Pretty expensive.
mouch is offline
post #8 of 47 (permalink) Old 01-28-2011, 12:03 PM
Sorry previous post 3 inch x 3 inch
mouch is offline
post #9 of 47 (permalink) Old 01-31-2011, 04:10 PM Thread Starter
Noob's Avatar
First Name: Paulo
I'll be using Cut 2D from Vectric for starters, but I'm thinking about getting Meshcam because I would be able to import .stl files from Solidworks.
Ryan360 likes this.
Noob is offline
post #10 of 47 (permalink) Old 01-31-2011, 04:16 PM Thread Starter
Noob's Avatar
First Name: Paulo
I've heard that the wireless 360 controller batteries didn't last very long. I was going to get rechargeable batteries, but when I went to Gamestop all they had at the time was wired controllers. I looked at it as a 1-time payment without having to buy batteries for it.
Noob is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.routerforums.com/cnc-routing/24959-new-cnc-build-using-80-20-extruded-aluminum.html
Posted By For Type Date
iB::Topic::Stock duplicator? This thread Refback 02-10-2011 10:12 PM
Build your own CNC cdndave CNC Routing 9 08-31-2010 12:20 AM
looking to build a cnc router thomas mahaffey CNC Routing 5 03-16-2010 07:52 AM
extruded aluminum stock brownie58 Table-mounted Routing 6 11-24-2009 10:36 PM
Self build cnc wood routers perseo CNC Routing 3 10-05-2009 12:21 AM
Planning CNC build Joework CNC Routing 4 04-23-2009 01:27 PM
