Other (Not Listed) Craftsman 6" Jointer 103.20660 - Router Forums
post #1 of 9 (permalink) Old 06-12-2011, 10:08 PM Thread Starter
Relative's Avatar
Default Craftsman 6" Jointer 103.20660
Craftsman 6" Jointer 103.20660.
Relative is offline
post #2 of 9 (permalink) Old 10-31-2011, 12:47 AM
First Name: Frank
Hello,
Needed manual for vintage jointer.Joined routerforums last night and found the pdf file.
Just wanted to thank Mike
Thank You
FMarinaro
FMarinaro is offline
post #3 of 9 (permalink) Old 01-30-2012, 04:23 PM
First Name: jerry
Default craftsman manual
thanks for the craftsman jointer manual infomation model 103.20660
jerry
1piglet1 is offline
post #4 of 9 (permalink) Old 09-19-2013, 02:47 AM
First Name: CAP
Default 103 jointer
Thanks for the manual didn't know if i would have found it on such an oler model. Bought the joinier at an estate auction
mrcap is offline
post #5 of 9 (permalink) Old 09-21-2014, 05:32 PM
First Name: Greg
Default Want to restore a Craftsman 6" Jointer 103.20660.
I just bought this Jointer for $40.00. It has a lot of rust, but the owner claims it ran last time he used (many years ago). I found that this machine requires a 220 receptical. My question is how to convert this to 110. I loaded some images. The plug comimg from the motor to the routher switch is two pronged. The plug coming out from the switch is not. Any guidance on this?
Gporpora is offline
post #6 of 9 (permalink) Old 09-21-2014, 08:00 PM
I am usually checking to see if I can convert a motor from 110 to 220 and not the reverse. Most motors have more torque and run cooler on 220. However, if you are sure you need to go backwards, some motors are wired for both voltages. The only way you will know is to take the motor connection box cover off and check the wiring schematic that is supposed to be attached to it or possibly at the motor specification plate on the side of the motor somewhere. The schematic will show how to change the internal wiring and the spec plate will probably show 110/220 where the voltage is specified. You should be safe with the motor phase. I don't think Sears ever sold anything that was 3 phase. Your photos are incredibly blurry so they really aren't much help but the first one appears to be a standard 110 volt plug in.
I had a Sears table saw that could be converted and a friend had a radial arm saw that he had converted so it is possible that it could have been. it's also possible that the owner did it and to save money he used a standard plugin on it. The 220 volt ones cost more. Be absolutely certain what you have before you plug it in.
post #7 of 9 (permalink) Old 09-21-2014, 09:20 PM
Welcome to the forum, Greg.
Sound advice.....
Sydney, Australia
jw2170 is online now
post #8 of 9 (permalink) Old 09-22-2014, 09:30 AM
First Name: Greg
Thanks for the advice. I don't really know my way around electrical things. I guess I could look into installing a 220 outlet. How would I know if it is definitely wired for 220?
Gporpora is offline
post #9 of 9 (permalink) Old 09-22-2014, 10:08 AM
Take the motor off the jointer and take to a motor repair shop. That is the surest way for you since you admit you're not familiar with wiring. Most won't charge for telling you what it is since it is a two minute job.
Other options is having a detailed conversation with the owner and find out if he converted it. If he did he can convert it back for you. If he did do it, or had a friend do it, AND he used a standard plug in and receptacle (a real no-no) then he had a dedicated outlet for it. You can test that outlet with a circuit tester easily. If you take the cover plate off and put one lead on the tester in an outlet hole and ground the other lead to the outlet box either outlet hole will light the tester up meaning both sides of the plug are live, i.e. 220 volt. Testing just the motor is a little more complicated.
I plugged a trouble light into a standard outlet that someone had converted to 220 once. The bulb exploded. That's why you're supposed to use the correct plugs and receptacles. I think that if your motor has been wired for 220 and you plug it into a 110 outlet it simply won't work but get an expert opinion.
Harbor Freight 6" Rabbeting Jointer Mike Tool Reviews 29 06-21-2017 10:51 AM
Other (Not Listed) Craftsman Jointer 113.20680 113.206930 Relative Craftsman Manuals 3 07-14-2011 09:22 AM
Craftsman Pro 1 1/2 HP 6" Jointer Shopmania Tool Reviews 1 08-23-2010 05:54 PM
Sold: Craftsman Jointer 4 3/8 in (almost free) kp91 Woodworking Classifieds 2 04-20-2009 05:34 PM
Cover for Jet 6" jointer AxlMyk Tools and Woodworking 7 08-16-2008 10:30 PM
