How To Repair Cracked Plexiglass - Router Forums
 7Likes
post #1 of 15 (permalink) Old 09-03-2016, 06:15 PM Thread Starter
Contributor of the Month
Default How To Repair Cracked Plexiglass
Any suggestions on how to repair cracked plexiglass? I have a 3 inch crack in a 1 piece storm window. It starts at the edge so I was thinking maybe spread it apart and use crazy glue?
JIMMIEM is offline
post #2 of 15 (permalink) Old 09-03-2016, 06:52 PM
kp91's Avatar
First Name: Doug
Plexiglass Acrylic Glue - IPS Weld-On & Plastic Adhesives Online
I would do a bit of checking on which adhesive is best for the type of acrylic you have. There is a decent guide on this link.
Mask as close as you can to the crack to avoid the glue from 'melting' the surface of the acrylic when it squeezes out.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 15 (permalink) Old 09-03-2016, 07:16 PM Thread Starter
Thank You. I looked at their web site and will give them a call next week.
JIMMIEM is offline
post #4 of 15 (permalink) Old 09-04-2016, 07:49 AM
CharleyL's Avatar
First Name: Charley
I would replace the Plexiglass with clear Lexan. It doesn't break. They make bullet proof windows from it, although those are much thicker than you will need. (Don't expect 1/8" Lexan to stop a bullet).
Charley
Central North Carolina
CharleyL is offline
post #5 of 15 (permalink) Old 09-04-2016, 07:52 AM
Charley
agreed but it is nick sensitive as is plexi...
post #6 of 15 (permalink) Old 09-04-2016, 08:22 AM
Gene Howe's Avatar
First Name: Gene
A cop told me that 1/4" Lexan would stop a 30-30. He used it behind his uniform shirt.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #7 of 15 (permalink) Old 09-04-2016, 08:45 AM
good luck w/ that...
post #8 of 15 (permalink) Old 09-04-2016, 10:47 AM
RainMan 2.0's Avatar
Maybe a BB gun lol .
On myth busters they shot a box made out of 1" lexan and the 30-30 went threw both sides like it was butter . Would stop small arms fire though .
And the only window that will stop a 50 cal is 1.6" thick transparent aluminum .
Ok ,I never insulate
RainMan 2.0 is online now
post #9 of 15 (permalink) Old 09-04-2016, 11:58 AM
Drill a small hole at the end of the crack or it may keep running. The hole distributes the stress.
post #10 of 15 (permalink) Old 09-04-2016, 01:13 PM
Good call Charles ,
I going to mention this also , as I swore I heard that before to
TenGees likes this.
Plumbing Repair Drywall Repair - What a mess MT Stringer Show N' Tell 33 02-23-2015 11:03 AM
Broken Screw Repair MT Stringer Tools and Woodworking 14 02-02-2015 08:29 AM
Patio chair repair JFPNCM Show N' Tell 10 07-26-2013 07:48 AM
Insulated rubber hunting boots have myriad little cracks and need repair Jack Wilson Lobby 26 06-11-2013 02:05 PM
Oval Mirror Repair 747trace General Routing 4 12-01-2010 11:53 AM
