Electromagnetic clamps? - Router Forums
 24Likes
post #1 of 28 (permalink) Old 02-09-2017, 03:54 PM Thread Starter
First Name: Quenten
Default Electromagnetic clamps?
I see a lot of effort going into designing & laying out dogholes for work tables. Has anybody ever thought instead, to use a sheet of steel under the top piece of plywood and an electromagnet as a clamp. You could place your piece wherever you wand it, place the magnet on it & turn it on. And there it would stay.
Round Electromagnets > EM137-115ac-222
Talk about easy...depending on the article you are clamping, you could use 2, 3 or 4 magnets. Whatever is needed. I think it would be a real timesaver as well.
Just a thought! Am I crazy?
Tonto1 is offline
post #2 of 28 (permalink) Old 02-09-2017, 04:10 PM
costs come to mind and I believe those magnets aren't strong enough to hold securely w/ a sheet of plywood under them..
also there is the cords that may get in the way...
and if you hit one of those mags w/ your tooling... ewwww boy...
and... and... and...
post #3 of 28 (permalink) Old 02-09-2017, 04:51 PM Thread Starter
First Name: Quenten
I considered that. But I see that those magnets are 12 volt, you could put a battery on top of them. That site has magnets that hold up to 640 lbs. Even if you used the 44 lb one I linked, if you used 2 or three of them, how much force is a screw down clamp exerting? Imagine being able to place a block anywhere to be used as a stop for cutting fixed lengths. Couldn't get much easier than that. But then again, just thinking out loud. Thought it would be fun to kick it around!
Tonto1 is offline
post #4 of 28 (permalink) Old 02-09-2017, 05:00 PM
They work great on metal working ,such as welding set up benches that have a steel top, But I agree with Stick it would be cost prohibitive for wood working.
Herb Stoops is online now
post #5 of 28 (permalink) Old 02-09-2017, 05:01 PM
I like the KISS/MISS route the best and old technology tools...
and what will those magnetic fields (think EMP) do to your high tech stuff...
MT Stringer, Shop guy and MYB506 like this.
post #6 of 28 (permalink) Old 02-09-2017, 05:08 PM
vchiarelli's Avatar
First Name: Vince
Quentin, I think the effort you're seeing by some members in the design and layout of dog holes isn't out of necessity but out of a desire to do it - at least that's my opinion.
I on the other hand, have a workbench made out of dimensional lumber with two sheets of 3/4" mdf on top. A row of dog holes in line with my vice is all I use. That bench has lasted me for years. I too believe in KISS - keep it simple s.......d. Electromagnets as clamps is really putting a lot of effort into it. No need to reinvent the wheel.
Shop guy, Herb Stoops and jj777746 like this.
vchiarelli is offline
post #7 of 28 (permalink) Old 02-09-2017, 05:41 PM
hawkeye10's Avatar
First Name: Don
You might be crazy but maybe not. All you have to do is develop and market it and you are rich.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 28 (permalink) Old 02-09-2017, 06:29 PM
MT Stringer's Avatar
...and what will those magnetic fields (think EMP) do to your high tech stuff...
Or your heart!
MT Stringer is online now
post #9 of 28 (permalink) Old 02-09-2017, 07:05 PM
Back when I was working, we had a couple of guys with pacemakers - they had to follow a proscribed - and very well defined - path through the shop to avoid the equipment that put out a field that would mess up the pacemaker. There was even a problem with one of the portable MPI machines, they used to put up tape barriers so that the affected workers would know not to get too close.
tomp913 is offline
post #10 of 28 (permalink) Old 02-09-2017, 07:11 PM
Originally Posted by MT Stringer View Post
Or your heart!
pacemaker or hearing aide...
insulin pump...
digital watch...
digital tools...
jj777746 likes this.
Best Clamps To Buy? rrrun Tools and Woodworking 27 12-19-2016 02:16 PM
Bessy Clamps On Sale DesertRatTom General Routing 14 11-17-2015 03:25 PM
Low cost banding clamps JAOB Tools and Woodworking 7 04-26-2015 06:20 PM
Making Clamps Easier to Use MT Stringer Show N' Tell 17 09-01-2014 02:03 PM
T Track Toggle Clamps Pop_pop1 Table-mounted Routing 4 07-29-2005 02:22 AM
