Broken belts - Router Forums
 9Likes
post #1 of 17 (permalink) Old 02-19-2017, 04:57 PM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Default Broken belts
Hello, guys.
Recently I was working in my garage sanding several wooden pieces for a project when a sandbelt was broken. Right away I took a replacement from the shelf but this broke almost immediately. I decided to repair both sandbelts using two different glues. The things are not available here lastly.
The first one was repaired wit CA glue but the results were a disappointment.
I turned to contac cement glue to repair the second piece. This time I used a piece of canvas as backup. Although the sandbelt worked to finish the job I think that something was wrong. This method was the better but not the best. The sandbelt is elongated more than the capacity my chinese machine is able to adjust for.
Any suggestion?
Hutzul likes this.
We, woodworkers are everywhere!!!
papasombre is offline
post #2 of 17 (permalink) Old 02-19-2017, 05:23 PM
Originally Posted by papasombre View Post
Any suggestion?
It's not worth the effort... IMHO... re-purpose them instead...
There's volumes here on this subject... and the upshot is... no...
But if you must...
First, peel the remaining factory tape off the belt splice. Cut a piece of cloth bias tape (wide single-fold type, available at fabric stores) about 2″ longer than the width of the belt. Lay one end of the belt, grit-side down, on the bench; then apply cyanoacrylate glue to the end of the belt. Lay half of the bias tape’s width on the glue, place waxed paper over the tape, and use a weight to press down on it for about 30 seconds, or until the glue sets. Wrap the belt around and repeat the gluing process to reconnect the ends of the belt. Trim off the excess tape, and the belt’s ready to use... For a short while....
the manufacturer uses a heat press (vulcanization process) set, kevlar tape/glue and the belts have a one year shelf life... The seams deteriate...
AccuBind Pro Binding Strips will work the best for repairs but you need a 250 - 300 degree heated press (carpet seaming iron snd s lot off pressure) to apply them correctly and the price of them will hurt your brain...
jj777746 and artman60 like this.
Stick486 is offline
post #3 of 17 (permalink) Old 02-19-2017, 08:30 PM
The belts themselves also deteriorate. I've had chunks break off old ones. They aren't even good for sanding blocks when they get to that condition.
Ray Newman likes this.
post #4 of 17 (permalink) Old 02-19-2017, 09:25 PM
vchiarelli's Avatar
First Name: Vince
Alexis - recently I was doing a lot of belt sander work and had purchased some belts from a Canadian hardware store chain - of the pack of 5 belts, 2 broke almost immediately. I chalked it up to cheap, poorly made belts.
However, I there is an arrow on the inside of the belts that indicates which way they should turn - did you check this?
Ray Newman and DesertRatTom like this.
vchiarelli is offline
post #5 of 17 (permalink) Old 02-20-2017, 10:00 AM
CharleyL's Avatar
First Name: Charley
Old belts several years old and older, and belts run the wrong direction will do this. When I first got a belt sander I stocked up on about 20 belts of different grits for it. I've learned the hard way not to do this. I now will only keep a few in the shop and buy just what I expect to need for the coming project when I need them. I've tried to glue them back together, but haven't found a glue that works well. I don't even bother trying any more.
Charley
Stick486, Herb Stoops and jj777746 like this.
Central North Carolina
CharleyL is offline
post #6 of 17 (permalink) Old 02-20-2017, 01:25 PM
Country: Mexico
First Name: Joseph Anthony
Unhappy
Charley
Exactly the same here
Cheers.
Joe
RÖENTGEEP is online now
post #7 of 17 (permalink) Old 02-20-2017, 02:28 PM
Charley
exactly...
Stick486 is offline
post #8 of 17 (permalink) Old 02-20-2017, 04:18 PM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
exactly...
Lesson learned.
I think that was the problem: Keeping them stored for long time.
post #9 of 17 (permalink) Old 07-22-2017, 01:29 AM
Same here
DonaHarris is offline
post #10 of 17 (permalink) Old 07-22-2017, 02:09 AM
Does storing them in a freezer help (with longevity)? Or vacuum packing them?
I'm thinking of those kitchen gadgets you can use at home.
Or...
Budget Tip: How To Vacuum Seal Food Without a Vacuum Sealing Machine | Kitchn
DaninVan is offline
King Seeley Drill Press - Belts patlaw Tools and Woodworking 9 07-05-2016 06:51 AM
Manual knee mill conversion - Timing belts Ryan360 CNC Routing 1 11-18-2015 08:36 PM
Broken Screw Repair MT Stringer Tools and Woodworking 14 02-02-2015 08:29 AM
Slow motion CNC broken tool laurent_parti CNC Routing 0 09-11-2013 04:40 AM
Is my new router already broken?? cablechewer Starting Off 4 12-06-2007 03:54 PM
