Led lights in shower niche - Router Forums
 11Likes
post #1 of 20 (permalink) Old 05-18-2017, 04:43 PM Thread Starter
RainMan 2.0's Avatar
Default Led lights in shower niche
Guys , I'm installing three 5mm white led's in the top of my Tub/ shower niche .
I've drilled 3/4" holes threw the wooden studs above the niche , and will be drilling small holes in the ceramic tile to slide the led holders in place .
My concern is mold due to condensation. I was thinking of putting fibreglass resin in the perimeter of the holes in the wood in order to make the wood waterproof , but that stuff is sure smelly .
Anything else you'd recommend to coat wood with to make it waterproof? It shouldn't get wet there , but the potential for condensation is pretty high.
Here's a pic of the back side of the wall where the wire will go down into one of the three holes . I can seal it on top of the hole easily enough once the wire is put in
Ok ,I never insulate
RainMan 2.0 is offline
post #2 of 20 (permalink) Old 05-18-2017, 05:01 PM
if everything stays dry and can breathe you'll be good to go...
Stick486 is offline
post #3 of 20 (permalink) Old 05-18-2017, 05:32 PM Thread Starter
Thanks Stick , I'm probably overthinking things as usual . These leds are not exactly water proof . I may have to put some silicone in the hole from the underside of the tile before I slide the led into place .
The problem being , if they ever burn out , I will need to pull them back down again in order to resolder the wire and replace them
post #4 of 20 (permalink) Old 05-18-2017, 05:35 PM Thread Starter
This is basically what I'm trying to do . It's more or less a night light for when I walk into the bathroom in the middle of the night
TenGees, Ed3443 and Herb Stoops like this.
post #5 of 20 (permalink) Old 05-18-2017, 08:29 PM
tomp913 is offline
post #6 of 20 (permalink) Old 05-18-2017, 08:53 PM Thread Starter
Originally Posted by tomp913 View Post
Neat . I may have to clean my toilet first
TenGees likes this.
post #7 of 20 (permalink) Old 05-18-2017, 11:27 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Rick, cut the tile so that the led is a snug fit and then a small smear of sanitary silicone around the led as you insert it will make a waterproof seal that will last years.
Dont use any kind of decorators caulk. Only sanitary ware silicone is 100% waterproof. Its what all glass aquariums are stuck together with.
When (not if) the led fails, a thin sharp blade will cut the silicone and you can replace the failed bulb.
Semipro and RainMan 2.0 like this.
sunnybob is offline
post #8 of 20 (permalink) Old 05-19-2017, 01:59 AM
Country: France
First Name: Gérard
Hello!
Imho:
A piece of wood left in such a place would get , after a few years covered with mold,
I would, at least use a chemical that kills mold and prevent insects to get in and have a good meal.
Regards
ggom is offline
post #9 of 20 (permalink) Old 05-19-2017, 08:53 AM
Garyk's Avatar
First Name: Gary
Interesting idea. LED's seem to be offering unique ideas we've never thought about.
Garyk is offline
post #10 of 20 (permalink) Old 05-19-2017, 10:23 AM
richjh's Avatar
First Name: Rich
Originally Posted by ggom View Post
Hello!
Imho:
Regards
Have the area treated with something like this:
BORA-CARE® WITH MOLD-CARE® » Nisus Corp
Basically, a tool is an object that enables you take advantage of the laws of physics and mechanics in such a way that you can seriously injure yourself - Dave Barry
richjh is offline
More about LED shop lights chessnut2 Lobby 8 12-18-2016 07:27 AM
TARGET LED lights rework Potowner1 Shop Safety 10 11-28-2016 11:56 AM
Craftsman 2HP / #320.17543 with LED lights tonyp General Routing 2 02-20-2007 11:44 PM
