Fireplace remodel - Page 2 - Router Forums
 14Likes
post #11 of 20 (permalink) Old 11-02-2017, 10:55 AM
First Name: mary
Welcome. What you have done looks great
marecat3 is offline
post #12 of 20 (permalink) Old 11-02-2017, 11:37 AM
On that triangular opening, I agree that the best solution is to cut a tight fitting triangluar piece and fit it in there. If the 90 is accurate, you can use a clear triangle to lay out the new piece slightly oversized, then fit with sanding. Put a couple of blocks inside to glue the triangular piece in nice and solid. If it's out of square, then it's you and the sandpaper until you get an exact fit. Use a small piece of the triangular stock to determine the set back of the supporting blocks.
I have the rocker switches in a 4 gang box in my living room, and they have tiny levers that run the dimmer built in. Nice looking setup and great to dim things down of an evening.
Overall, it is a really nice looking job you've done there. I don't blame you for not tearing it all out to get it square. If you get a chance, watch the Tom Hanks film "The Terminal", in which he builds some really creative structures from what's at hand. Your manle brings that film to mind.
post #13 of 20 (permalink) Old 11-02-2017, 01:40 PM Thread Starter
First Name: Phillip
Thanks for the advice. It turns out my wife wants to leave the triangle open. It will make a good hiding place for excess cord length when decorating.
After cutting some test pieces and debating the pros and cons I decided to leave the switch and just use the same measurements for the JP on both sides. Since it is designed to be basically hidden I think it will function and it doesn?t look as bad as I thought it would. I am going with a toggle type dimmer switch. That switch is for the uplighting in the top run of the crown molding above the JP.
marecat3 and TenGees like this.
Phillip
PDSMustang is offline
post #14 of 20 (permalink) Old 11-02-2017, 01:55 PM Thread Starter
First Name: Phillip
I also added some hidden features to this build. I have three parts if the JP that are secret doors and access to key areas for future owners and opportunities. The main feature is the inner ring of the panel immediately above the mantel. While we are not putting our tv over the fire place for several reasons some future owner may decide they want to. So it pops out and hides an outlet and 2? conduit run to the left side for easy routing of cables.
The left side has a panel that pops out reviewing the other end of the conduit run so media plates can be installed.
The right side has a panel that pops out to gain access to the LED up light electrical box for when it finally burns out.
Phillip
post #15 of 20 (permalink) Old 11-02-2017, 04:21 PM
Pounamu's Avatar
Country: New Zealand
First Name: Keith
Send a message via AIM to Pounamu Send a message via Skype™ to Pounamu
Originally Posted by Pounamu View Post
Sorry, Ross, it's all beyond the comprehension of a simple country lad like me! But welcome to the forum anyway!
Sorry, should have said Phillip.
If eating carrots improves the eyesight, how come there are so many dead rabbits on the roads?
Pounamu is offline
post #16 of 20 (permalink) Old 11-02-2017, 04:39 PM
JFPNCM's Avatar
First Name: Jon
Well thought out and executed. Appreciate the details in the share.
Jon
JFPNCM is offline
post #17 of 20 (permalink) Old 09-27-2019, 10:36 AM
That looks really good.
lmgoodhair is offline
post #18 of 20 (permalink) Old 09-27-2019, 02:40 PM
Nickp's Avatar
First Name: Nick
Excellent work...looks much better than the original. And great solution with the switch...light looks real nice...
Nick
Nickp is offline
post #19 of 20 (permalink) Old 09-27-2019, 07:37 PM
David Bradford's Avatar
First Name: David
Nice upgrade on that.
David drafter @ Linear Fine Woodworking in Phoenix
[email protected]
http://www.linearfinewoodworking.com
David Bradford is offline
post #20 of 20 (permalink) Old 09-27-2019, 08:09 PM
Some of these older posts are really good.
Basement Remodel berry DIY and Renovation 16 04-13-2016 01:07 AM
Home Renovation TRN_Diesel Project Plans and How To 99 07-26-2014 11:25 PM
Closein up an old fireplace dmagor DIY and Renovation 7 09-09-2013 01:58 AM
Kitchen remodel - reuse cabinets or not? reikimaster DIY and Renovation 7 06-23-2011 09:49 AM
