Fireplace remodel - Router Forums
 14Likes
post #1 of 20 (permalink) Old 11-01-2017, 05:31 PM Thread Starter
First Name: Phillip
Default Fireplace remodel
Hello,
I'm new to the forum and I'm already finding things that I wish I had known about a few months ago. I am about to complete a DIY fireplace remodel in my home and I would like to get some opinions on the job as a whole and I also need some advice on one small section that has got me stumped.
The original was supposed to be an electric only fireplace with with glass tile and a mirrored mantel. It was basically a big brown monolith that did nothing since the electric was never hooked up. There was quite a bit of re-planning as I kept finding things as I tore away the layers. Like the recessed TV mounting. I decided to use that for the new rebuild initially but I realized that was going to make matching up the new stone work VERY difficult. At least for me. My wife and I ultimately decided the TV over the fireplace was just not what we wanted and it's not the best thing for the TV anyway. So we ended up going with judges panel and a new wood mantel with stone fireplace and hearth.
Did I make the right choice? Too late now, but I would like the input.
JFPNCM, DaninVan, marecat3 and 5 others like this.
PDSMustang is offline
post #2 of 20 (permalink) Old 11-01-2017, 08:31 PM Thread Starter
First Name: Phillip
So here?s the thing I got stuck on. When I got around to the ends of my mantle I ended up with a hole I couldn?t figure out how to fill. I?ve attached a picture.
Phillip
post #3 of 20 (permalink) Old 11-01-2017, 08:39 PM Thread Starter
First Name: Phillip
I?m also not sure how to finish up the judges panel on one side. I have a 3? perimeter around the grams but on this side I have a light switch in the way. Do I just use the 3? from the mant l edge or move over to 3? from the light switch. The switch plate will just barely fit inside the 3? perimeter.
Phillip
post #4 of 20 (permalink) Old 11-01-2017, 09:16 PM
If that's drywall, cut it open and move the switch to a more artful location. Change the switch style to one of those flat rockers, or a dimmer if appropriate. It will go better with the look. If it's not drywall, the patching will have to be much more carefully done, but will still work. Remove the trim and cut the wall open under the trim line. The trim will cover the patches edges. You can place the switch centered in the panel, high or low. I would most likely replace the panel if it's ply. and use the trim to cover the seam.
If you use one of the big rectangular rocker switches with or without dimmer, I would also replace the AC outlet you have there with a similar style outlet.
BTW, welcome to the Forum, glad you joined the fun. Looks like you're pretty experienced. That's a nice job.
post #5 of 20 (permalink) Old 11-01-2017, 09:44 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is offline
post #6 of 20 (permalink) Old 11-01-2017, 11:07 PM
Pounamu's Avatar
Country: New Zealand
First Name: Keith
Send a message via AIM to Pounamu Send a message via Skype™ to Pounamu
Sorry, Ross, it's all beyond the comprehension of a simple country lad like me! But welcome to the forum anyway!
If eating carrots improves the eyesight, how come there are so many dead rabbits on the roads?
Pounamu is offline
post #7 of 20 (permalink) Old 11-01-2017, 11:20 PM Thread Starter
First Name: Phillip
DesertRatTom
Thank you.
Not sure I have the fortitude to reposition the switch. But it looks ok to me and it is supposed to be relatively hidden. I will change it out to the rocker type. Don?t know why I didn?t in the first place. Will also swap out the outlets.
It?s 3/4 plywood outer shell on top of a Very out of square framing job with a layer of dry wall in-between. I used the plywood to cheat the squaring so I wouldn?t have to rebuild the whole thing. Used some biscuit joins to help keep things lined up and square as I added back the lower sections.
Phillip
post #8 of 20 (permalink) Old 11-01-2017, 11:25 PM
Welcome to the forum. The tv and the fireplace would have competed with each other for attention. As well, the tv would have been too high to watch comfortably.
About all you can do to finish the ends is to fill the hole with as tight a fitting triangular piece as possible. Anything else will look worse. If the ends are visible then they should match the rest of the mantle which means wrapping the crown moulding all the way around. Other than that it's a very nice looking job.
DaninVan likes this.
post #9 of 20 (permalink) Old 11-02-2017, 09:00 AM
First Name: Art
Why not rewire the switch into the receptacle on the side with something like this
https://www.homedepot.com/p/Leviton-...-0WS/202035011
Then make a new mantle because the one you have looks too short to be able to wrap the crown molding around. You will also have to re do the crown molding because that is too short to make an outside corner. Last you will have to make the bottom section of the molding frame narrower so that it can be installed without running into the mantle. However it would probably look better if you eliminated the lower molding altogether. Although it's a fair amount of work it has to be done if you want to be able to look at it and be happy with it.
mgmine is online now
post #10 of 20 (permalink) Old 11-02-2017, 09:27 AM
First Name: frank
Cherryville Chuck, Some of you people on this forum just do great work. This project is a true example. Looks just great.
Tagwatts is offline
Basement Remodel berry DIY and Renovation 16 04-13-2016 01:07 AM
Home Renovation TRN_Diesel Project Plans and How To 99 07-26-2014 11:25 PM
Closein up an old fireplace dmagor DIY and Renovation 7 09-09-2013 01:58 AM
Kitchen remodel - reuse cabinets or not? reikimaster DIY and Renovation 7 06-23-2011 09:49 AM
