DIY Feather Board Slide - Router Forums
 12Likes
  • 10 Post By Tonto1
  • 2 Post By Tonto1
post #1 of 10 (permalink) Old 11-24-2017, 06:14 AM Thread Starter
First Name: Quenten
Default DIY Feather Board Slide
Since I can't find any Aluminum Track, I had to make the slide. No bid deal, just thought I'd post some pictures.
I cut down a piece of Oak fire wood. Had to make it match the track and be level with the table. Counter suck the bolts and done. They are vey tight and don't wobble at all! They work great! Got them @ HF by the way.
fire65, JFPNCM, DaninVan and 7 others like this.
Tonto1 is offline
post #2 of 10 (permalink) Old 11-24-2017, 06:17 AM
nicely done...
post #3 of 10 (permalink) Old 11-24-2017, 06:26 AM Thread Starter
First Name: Quenten
Thanks Stick. It was kinda tricky with just the table saw. Would have been a lot easier with a router table and a band saw. Those will come with time and funds! Since I made these I have picked up an Grizzly 8" jointer (used but mint) and a Grizzly 15" Planer (new) and various hand tools. Great hobby!
DesertRatTom and Roy Drake like this.
Tonto1 is offline
post #4 of 10 (permalink) Old 11-24-2017, 02:57 PM
"and a Grizzly 15" Planer (new)"
-Quenten
I'm jealous!
Sorta like this?
https://www.kmstools.com/king-canada...-planer-100968
DaninVan is offline
post #5 of 10 (permalink) Old 11-24-2017, 05:13 PM
jj777746's Avatar
The King Canada planer is built to last by the look of it eh Dan? Very sturdy.I want one
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #6 of 10 (permalink) Old 11-25-2017, 12:30 AM
Nice fix. Having good gear really makes a difference. Looking forward to seeing your projects. But doing projects is addicting.
post #7 of 10 (permalink) Old 11-25-2017, 01:27 AM
I've had one for maybe 20 years and pushed several thousand board feet of lumber through it. It's a workhorse. 1/8" cut per pass. There are a few other brands that are the same planer. My older model is 16" wide and I've run 6 x 16" timbers through it and 2 x 10s on edge. The newer ones won't raise that high.
post #8 of 10 (permalink) Old 08-27-2018, 02:41 AM
ritabos's Avatar
I recently found myself in need of a featherboard on my table saw and found your post, thanks for sharing it.
ritabos is offline
post #9 of 10 (permalink) Old 08-27-2018, 11:02 AM
Honored Member
harrysin's Avatar
First Name: Harry
There is another way on a non magnetic table, glue a sheet of galvanised iron on to the table top and use the magnetic style of feather board. The second shot of a corner of my shed shows such a sheet of galvanised iron glued beneath the grinder, but in this case to stop water from dripping into the draw.
Name:	corner of shed.jpg
Harry
harrysin is offline
post #10 of 10 (permalink) Old 08-27-2018, 12:46 PM
For the saw tables with straight slots (no tee shape) or for drill press or router tables with aluminum channels added you can use this pinch bar I designed to hold feather boards in place. It's sitting on top of a thin strip ripping jig I made. It will hold with a surprising amount of force without tightening the knobs that much.
Name:	thin rip jig 003.jpg
feather board problems GaryHerman Table-mounted Routing 5 02-18-2013 12:51 PM
Riving Knife Along With Feather Board Jerry Bowen Tools and Woodworking 29 11-28-2012 04:30 PM
riving knive vs: magnetic feather board Jerry Bowen New Member Introductions 4 05-24-2012 11:12 AM
