adhesive question - Router Forums
 7Likes
post #1 of 46 (permalink) Old 01-01-2018, 07:05 PM Thread Starter
First Name: Frank
Default adhesive question
Not sure where to ask this question, so will start here. Mods please repost elsewhere if need be. Thanks.
I'm making a picnic table with pressure treated dimension lumber. The top will be made up of varying width sized 2x somethings. I have made a template to rout a pocket in one of the boards into which I want to permanently afix an aluminum plaque into. I have sized the pocket to be just a bit larger than the plaque to allow for any shrinkage or contraction of the wood. It would be flush with the top of the table.
My question is what would be the best adhesive to use to install it? I'm thinking maybe liquid nails or some other outside weather proof adhesive in a tube for a caulking gun. Mechanical fasteners or screws won't work, as I don't want to drill any holes in the plaque. I thought I could use what ever adhesive I decide on to fill the minute space between the plaque and the board. Otherwise, maybe some exterior silicon caulk? Any ideas to offer me? Thanks.
routafinger is offline
post #2 of 46 (permalink) Old 01-01-2018, 07:12 PM
PL Premium...
http://www.loctiteproducts.com/p/12/...n-Adhesive.htm
note...
it will expand so weight down your plaque till the adhesive is cured....
Danman1957, Semipro and hawkeye10 like this.
post #3 of 46 (permalink) Old 01-01-2018, 07:20 PM
Semipro's Avatar
First Name: John_*
+1 with Stick ( construction grade adhesive)
Semipro is online now
post #4 of 46 (permalink) Old 01-01-2018, 07:47 PM Thread Starter
First Name: Frank
Thanks for the quick replies. I haven't used the PL Premium before, so now I guess my questions would be how much it will expand, and how low will it take to cure? If I clamp the plaque to the board, will the adhesive expand up around the outside edge of the plaque? Then be easily cleaned off with a rag and a sharp chisel or putty knife? Should I "butter" the adhesive into one thin layer, or simply apply a bead to about half of the surface? Please bear with the questions. Thanks.
post #5 of 46 (permalink) Old 01-01-2018, 08:03 PM
held in place it won't expand much...
read the tube for cure time.....
MS cleans it up really well while it's wet...
dry it will shave/scrape easily..
one side application and more isn't better...
post #6 of 46 (permalink) Old 01-01-2018, 08:35 PM
JOAT's Avatar
First Name: Theo
Not a good idea, using some types of pressure treated wood.
Safety information about usage of treated wood - PTW-Safety
JOAT is online now
post #7 of 46 (permalink) Old 01-01-2018, 11:17 PM
hawkeye10's Avatar
First Name: Don
Frank I would go with what Stick suggested. I wonder if a few holes should be drilled under the plaque to let water seep out. In the winter if water freezes and thaws that might be a problem. Just a thought I had.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 46 (permalink) Old 01-01-2018, 11:39 PM
No silicon, it will fail within two years my guess. I also recommend PL, either 400 or Premium, both are waterproof. It will expand very little. Rut a small block of wood on top of the plaque. Put similar blocks on either side of it. Lay a board on top. The weight of the board is probably enough.
Danman1957 likes this.
post #9 of 46 (permalink) Old 01-01-2018, 11:53 PM Thread Starter
First Name: Frank
A good point, but I think most of the pressure treated lumber sold today isn't nearly as deadly as the older lumber preserved with arsenic.
post #10 of 46 (permalink) Old 01-01-2018, 11:54 PM Thread Starter
First Name: Frank
Thanks for all of the info.
Question About An Adhesive Jerry Bowen Tools and Woodworking 5 12-08-2012 09:24 PM
Adhesive & Thickness Question for Router Table Top aphead Table-mounted Routing 2 04-14-2012 08:33 AM
Question About This Forum Jerry Bowen Tools and Woodworking 4 03-30-2012 09:46 AM
